Holley adjustable FPR w/1:1 boost ratio compensation
Old Nov 7, 2003 | 11:16 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Just saw this...might be old news. Might be useful for those running Vortech FMUs that want odd numbers, ie 5:1, 7:1, 9:1, or JWT ECU guys that don't need that much of a fuel pressure increase while running bigger injectors.
1:1 boost compensating design, meaning that for every psi of boost it will increase fuel pressure by 1psi. Range of adjustment is 15-65psi. This regulator also features a manifold vacuum reference port so the optimum injector fuel pressure can always be maintained, even under boost. A built-in gauge port for fuel pressure monitoring.
P/N 512-504-5
Old Nov 7, 2003 | 11:18 AM
Sprint's Avatar
so when are you going to actually own a boosted maxima?
Old Nov 7, 2003 | 11:36 AM
IceY2K1's Avatar
Never...when are you?
SR20DET 240SX someday soon though.
Old Nov 7, 2003 | 12:06 PM
IceY2K1's Avatar
BTW...rice juice don't count.
Old Nov 7, 2003 | 12:09 PM
jdmmax's Avatar
boost in a bottle get it right....
Old Nov 7, 2003 | 12:24 PM
IceY2K1's Avatar
Same thing!
He knows what I'm talking about.
Old Nov 7, 2003 | 01:02 PM
Stephen Max's Avatar
Where did you see this?
Old Nov 7, 2003 | 01:03 PM
IceY2K1's Avatar
Page 20 of "Modified Mag".
Says visit www.holley.com or call (800)HOLLEY-1
Old Nov 7, 2003 | 01:05 PM
IceY2K1's Avatar
http://www.holley.com/HiOctn/ProdLin...512-504-5.html
This precision adjustable fuel metering regulator is the ultimate fuel pressure control unit designed to work on all naturally aspirated EFI, turbo and supercharged applications like vehicles that run in the Pro Street, Pro Import and Outlaw classes. This is a 2 port 1:1 boost compensating return style regulator that is adjustable from 15-65 PSI + boost reference and is designed to be used in conjunction with any electric EFI fuel pump.
Features built in gauge port, mounting bracket, two AN -8 O-ring fittings and a AN-6 O-ring return fitting.
All racing regulators come Black hard anodized for ultimate durability.
Features
Designed to regulate high fuel demands for naturally aspirated EFI, turbo, supercharged and NOS race applications.
Engineered to regulate extreme flow volumes generated by racing fuel systems.
Allows adjustment from 15-65 PSI + boost reference.
Precision CNC machined 6061 T-6 Billet aluminum.
-8AN & -6AN O-Ring style fittings included to adapt to steel braided fuel lines.
Includes detailed installation instructions.
Old Nov 7, 2003 | 01:12 PM
IceY2K1's Avatar
Looks like $187.95 here:
http://www.carshopinc.com/index.php/cPath/65_70
Probably cheaper if you look hard.
Old Nov 7, 2003 | 01:21 PM
IceY2K1's Avatar
What are you thinking Stephen?
Old Nov 7, 2003 | 04:13 PM
Craig Mack's Avatar
All YOUR grammer belong to me
He is thinking it's time to get these dawgon dentures changed dagnabbit!
Old Nov 7, 2003 | 04:20 PM
IceY2K1's Avatar
WTF?
Old Nov 7, 2003 | 06:07 PM
Craig Mack's Avatar
:jeffy
WTF?
Get with the program, man! Now that you've killed the joke, I might as well explain it. Our good friend, Mr. Stephen Manifold, aka Stephen Max, is a senior citizen. Therefore, I just like giving him a hard time.
Old Nov 7, 2003 | 09:42 PM
mtcookson's Avatar
the aeromotive fpr looks better and does the same thing. i got mine for 130 i believe.
Old Nov 7, 2003 | 09:50 PM
IceY2K1's Avatar
Got links?
Old Nov 7, 2003 | 10:33 PM
mtcookson's Avatar
www.aeromotiveinc.com
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
leatherneck
Sep 30, 2015 09:16 PM
