Injector O-Ring Part Number
Old Nov 7, 2003 | 01:00 PM
iansw's Avatar
Anyone have the part number for the O-Rings that are to be replaced when 300zx Injectors are installed?
Anything else I need?
A Search tuned up nothing.
IanS
Old Nov 7, 2003 | 01:49 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Scroll down and see if those on the paper make sense:
http://forums.maxima.org/showthread.php?t=256147
Old Nov 9, 2003 | 12:37 AM
iansw's Avatar
I called up and checked those part numbers today with the local Nissan Dealer.
He said they don't match anything in their database. Then again, he couldn't find any O-Rings at all. So maybe he's just stupid.
Anyone else have any part numbers for the 300ZX TT Injector O-Rings?
Thanks!
IanS
Old Nov 9, 2003 | 05:21 PM
tampamax's Avatar
ian are you looking for the seals that go between the fuel rail and the injector gully's? If you are looking for the other seals, don't bother cause i'm sending the rail and all, still assembled to you. I dont believe you will need anything to drop these in.
Old Nov 9, 2003 | 05:44 PM
Confused's Avatar
Permanent Maxima.org Resident
300zx injector part #
injector - 16600-21U00
two o rings that actually go on the injector 16618-10V05 and 16618-53J00..
insulators for between the injector and the mounting hat 16635-53J00
Old Nov 9, 2003 | 07:04 PM
iansw's Avatar
Whoa - right on!
Old Dec 19, 2003 | 09:22 AM
Prodeje79's Avatar
Isn't there an upper and lower injector insulator part numbers?
Are they not needed?
Any advice appreciated as I need to order my 370cc injectors ASAP!
Old Dec 19, 2003 | 09:29 AM
iansw's Avatar
I did end up buying the lower insulators - may as well replace them while I'm in there.
I don't have the PN on me right now but I will later today when I go pick them up.
I'll post when I get them.
Old Dec 19, 2003 | 11:56 AM
Prodeje79's Avatar
Thanks ian!
Here is the list, thanks Stephen!
According to the Nissan FAST system,
16600-21U01 is an alternate injector part number for 16600-21u00. Either one should work.
16618-10V05 is the lower o-ring
16618-53J00 is the upper o-ring
16635-53J00 is the upper insulator
16635-88G00 is the lower insulator
That should be everything you need.
MR2 T'd
Jul 9, 2021 05:06 AM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
AcuraLegend
Sep 22, 2015 04:22 PM
dvcamp
Sep 18, 2015 10:17 AM
