Has anyone else had a BIG problem with the v2 bracket?
Old Dec 19, 2003 | 09:57 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
So some of you know my problems with this installation and its taken forever.
Last night i went to run another belt so i could finally boost and i go to take off the bracket and the same part fell off. its the arm that houses the idler pulley.
the idler pulley seemed to have a flat spot on the bearing and it didn't spin that great, but for the tension on the belt to cause that make me wonder what kind of machining they do at stillen and vortech.
they are definitely getting a call today
pics will be posted later, but this is the part that im talking about
Old Dec 19, 2003 | 10:32 AM
BlackCat's Avatar
RIP '98 Maxima SE
How did you break the arm off? The whole mounting plate is supposed to be in one piece. I must have missed your earlier posts. Did you buy the kit used?
Old Dec 19, 2003 | 10:47 AM
JAY25's Avatar
Metal or plastic pulley? if its metal you will need a set of pliers to remove that ring that holds it in place. Place a socket under the pulley. Grab a rubber mallet and bang it out and head out to NAPA and replace it. If its plastic I dont think you can do that. I ll check my plastic pulley this evening and get back to you.
Old Dec 19, 2003 | 10:55 AM
ejj's Avatar
ejj
So wait, is that your second bracket that you broke?
BTW the bracket is made by Stillen. Vortech has nothing to do with it.
Old Dec 19, 2003 | 11:58 AM
JAY25's Avatar
I read to fast, he said the same part broke off again? How did you do that? Then only thing I can think of that part breaking off is if he tighten the beeejeeeeez out that belt to place enouh tension on the belt when it spins that it snaps that piece right off.
Old Dec 19, 2003 | 01:47 PM
slimer's Avatar
same part, new reinforced bracket. i didnt have the belt on the first time at all.
didnt have too much tension on this one and i have the metal pulley
im going to have stillen give me another new bracket and get the other two welded and machined so i can have a couple of extra laying around
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
jcvgn
Sep 13, 2015 11:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
slowlifer
Sep 8, 2015 05:53 AM
