Day 2 and 3
Old Nov 9, 2003 | 07:09 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Day 2 and 3
Well day 2 and 3 went bad..lol..
Not having all the tools and required items sucks.
I am gonna wirte a thread on what I needed and did not have and what went wrong and how I could have fixed it when I am done.
But the tranny and motor are OUT
Here is a pic from day 2
Old Nov 9, 2003 | 07:10 PM
Bags's Avatar
Another pic of the clutch
Old Nov 9, 2003 | 07:11 PM
Bags's Avatar
Day 3, motor removed.. ALOT simpler than I thought.. although ejj's posts helped..THANKS
Old Nov 9, 2003 | 07:13 PM
Bags's Avatar
This is WRONG.. REMOVE THE CLUTCH AND FLYWHEEL BEFORE YOU HOIST THE MOTOR OUT>
YOU CAN'T CONNECT AN ENGINE STAND WHILE THE CLUTCH AND FLYWHEEL ARE ATTACHED
Old Nov 9, 2003 | 07:14 PM
CiViC KiLLeR's Avatar
That looks real bad you have no tranny know wonder your car messed up.LOL
Old Nov 9, 2003 | 07:15 PM
Bags's Avatar
Look at the ugly rust, I planed to fix that.
Old Nov 9, 2003 | 07:16 PM
Bags's Avatar
Flat white rustoleum took care of it also beat that bracket off the car
Old Nov 9, 2003 | 07:18 PM
Bags's Avatar
I also took out the motor mounts and filled them with glass weld... they did not look that bad for having 131,000.. sorry no pics, I will have some when they are dry.
And here is the motor on the stand, notice where the attach points are. Lesson #112 on this project..lol
Old Nov 9, 2003 | 07:19 PM
JUST KIDDING hope it works out man.
Old Nov 9, 2003 | 07:20 PM
stephenlc's Avatar
Good luck on everything. Take your time and do everything right.
Old Nov 9, 2003 | 07:32 PM
ejj's Avatar
ejj
See, your problem is you need a better engine stand:
Can't go wrong with a spare tire!!
Glad to hear is progressing, and that I somehow helped.
Putting the new engine in is a lot easier than removing the stock one. Now that you have a really good idea about where everything is and how its bolted up, etc, it makes the job a lot easier!
Old Nov 9, 2003 | 07:47 PM
|Bijan|'s Avatar
UCF Lexus
LOL - I SWEAR I said that to Kirk on day 1....
Originally Posted by bijan gxe
We can just use an old tire...just set the oil pan in the hole and tie it up.
Old Nov 9, 2003 | 10:25 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
that's exactly how we did mine... oil pan in the hole... works well.
Old Nov 10, 2003 | 11:47 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Heh heh heh...ghetto, but very effective engine stand. Hell, when I was transporting my GTO engine back and forth to the shop, I used that method in the back of my pickup
Old Nov 10, 2003 | 12:03 PM
ejj's Avatar
ejj
Oh, I've got that picture too:
http://www.ericj.org/maxima/img/engi...e_in_truck.jpg
Old Nov 10, 2003 | 12:26 PM
|Bijan|'s Avatar
UCF Lexus
Bwaha....that ranger looks kinda skeered of the weight in the back.
Old Nov 10, 2003 | 12:57 PM
ejj's Avatar
ejj
Made it the 3 miles between my house and my dads with that weight...twice!
Old Nov 10, 2003 | 04:33 PM
|Bijan|'s Avatar
UCF Lexus
LOL - Don Vito!!!!
Bags, call me or AIM me when you wana start this Friday
Old Nov 10, 2003 | 08:22 PM
OT n00bs FTMFCSL
Originally Posted by ejj
Nifty! You have the same color truck as me
but I have a V8...
Old Nov 10, 2003 | 10:45 PM
Bags's Avatar
Yeah but I needed the stand to hold the engine as I tear it apart over the coming months.
And your thread about what you did what days helped me gauge how long it should take and how hard it was
Old Nov 11, 2003 | 04:34 PM
ejj's Avatar
ejj
Sweet! Glad I could help! Have you found that you're about on the same schedule I used, or are you getting things done faster, etc?
I just tore the engine apart on a pallet in my garage. Because I never plan to put it back together, I didn't have to worry about details...it was actcually kinda fun!
http://www.eric.org/maxima/img/vq_teardown
Take lots of pictures of the teardown/failure. I'm interested to see what exactly failed (do you know...I don't recall reading it?).
Old Nov 11, 2003 | 10:56 PM
Bags's Avatar
LOL - Don Vito!!!!
working friday, SUNDAY will be the next day
Old Nov 11, 2003 | 10:59 PM
Bags's Avatar
Link does not work...
No I don't know.
I have a feeling a combination of overheating, driving like an idiot, detonation.. and maybe another item.
I will have lots of pic.
I am gonna start from the top and work my way down to the piston head. Tjen I may go from the bottom up.
I have never taken a motor apart, this is gonna be fun
Old Nov 12, 2003 | 05:58 AM
ejj's Avatar
ejj
No I don't know.
Doh...got my domain name wrong.
http://www.ericj.org/maxima/img/vq_teardown/
That's basically how I did it. Took the oil pan(s) off, timing covers and chains next. Rear timing cover, cams, heads, mains, crank, pistions & rods. Only special tools I needed were a pully/gear puller (for the timing gear on the crank), and a 10mm hex bit for the head bolts.
Its a lot easier (and I'd imagine less stressful) when you don't need to put the engine back together.
Old Nov 12, 2003 | 06:02 AM
ejj's Avatar
ejj
but I have a V8...
It ain't my truck...its my dad's. Is that est damn thing I've ever had to drive...
...but it does work
Old Nov 12, 2003 | 06:05 AM
deezo's Avatar
Looking at this pic, It's crazy to see how things look behind the engine. You can only have a mental picture when removing the rear bolts on the manifold and on the EGR.
Old Nov 12, 2003 | 08:27 AM
|Bijan|'s Avatar
UCF Lexus
Aiight - Sunday it is
Old Nov 12, 2003 | 02:43 PM
Bags's Avatar
You'll be amazed at how things are connected and what needs to come off to remove some items.
Old Nov 12, 2003 | 08:09 PM
ejj's Avatar
ejj
But from this point on, it will seem really easy for you! Taking off the intake manifold no longer seems like a big task!
Old Nov 14, 2003 | 02:37 PM
JAY25's Avatar
I removed a manifold and put back together in 1hr 45 mins. I used a electric impact wrench and gear wrenches. But I did not disconnect the hoses just one. Not hard at all to get to the rear set of injectors. I climbed on top of the motor to get to the 4 rear bolts for it to come off.
Old Nov 14, 2003 | 03:33 PM
ejj's Avatar
ejj
Yeah, I'm down to getting the IM off in about 20 minutes. I didn't put the rear bolts back in (the brackets off the right head), just the EGR bolts. I remember taking it off the first time though, and trying to visualize the bolt layout back there without seeing it...made it a lot more complicated.
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
