have a chance to buy VQ30DET engine or parts!!!
Old Nov 30, 2003 | 07:04 AM
stephenlc's Avatar
Well I e-mailed some companies if they had an VQ30DET's around in storage and one has sent me some pictures and asking what I want from it. I want to know what everyone thinks on what I whould get from there? I definitily want the pistons and connecting rods but what else could I get from the engine. I think Tilley is the only one who has doen the swap and I just wanted to know what I could take from the RWD VQ30DET and put on my Maxima. I hope I get some responses fast!
Old Nov 30, 2003 | 07:17 AM
MardiGrasMax's Avatar
I want the intake manifold, it takes some machine work to make it fit according to Tilly, but I would be interested in buying that to suplament your purchase. Every thing else is basically the same. Rods & pistons are what you are after.
Old Nov 30, 2003 | 07:38 AM
stephenlc's Avatar
So intake manifold, connecting rods, pistons.
Would anything else be benificial like exhaust manifold? Cams? Heads? Any other valvetrain components? Injectors? Fuel Rail? Anything else?
When I get a chance I post pictures later okay.
Old Nov 30, 2003 | 08:05 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Since it was for a RWD car, the exhaust manifolds may not be of any use to you (except for design). The cams are probably pretty mild, but why not go ahead and the the fuel rail and injectors...
Old Nov 30, 2003 | 08:34 AM
I dount think anything elso would be usefull. Heads and cams are the same for sure.
Old Nov 30, 2003 | 09:54 AM
stephenlc's Avatar
Maybe I get the heads for an extra set to port and polish!
Old Nov 30, 2003 | 10:04 AM
its allways good to have spares.
Old Nov 30, 2003 | 11:48 AM
OT n00bs FTMFCSL
I totally agree...spares of all kinds will prove to be very useful.
Old Dec 1, 2003 | 06:43 AM
Redmax's Avatar
Redlinemax Owner
What price did he quote you, i have det pistons that i was thinking about selling , have been trying to sell them for 2 months now but was just going to put them in my car this week. Let me know what you are going to do. The connecting rods according to tilley are not much bigger than the stock ones
Old Dec 1, 2003 | 07:56 AM
stephenlc's Avatar
How much would you sell the pistons for and do the come with piston rings? I am not looking for thick connecting rods, I only want to push like 12-15 psi and I don't think I will need stronger ones with the lower compression.
Old Dec 1, 2003 | 08:05 AM
stephenlc's Avatar
No quote yet, he should get back to me this week.
Old Dec 1, 2003 | 08:17 AM
Redmax's Avatar
Redlinemax Owner
350 shipped Otherwise they are going in my car thisweek. Yes they do come with the rings. They are also cleaned and prepped for installation. nothing needs to be done to them but be installed
Old Dec 8, 2003 | 01:47 PM
Thaniel's Avatar
Did you get pics and or parts? I may be interested in an oil pan if they don't want too much. Can you hook me up with these guys?
Old Dec 8, 2003 | 03:02 PM
mtcookson's Avatar
the exhaust manifolds wouldn't be a bad idea if you guys don't want the reverse y-pipe thing. my vg30et came out of a rwd car and dropped right in my 3rd gen. if the exhaust manifolds are anything like mine you have a rear manifold that goes to a crossover pipe then goes to the front manifold to the turbo. it should fit fine unless there is something sticking up from the tranny.
Old Dec 8, 2003 | 03:18 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I'm no VQ30DET expert, but be careful with oil pans from RWD cars...depending on where the turbo is mounted and a few other factors the tap might be inconveniently positioned when you put it on the Maixma. the sump might also be at a n awkward position as well because of the Maixmas x-memeber.
Old Dec 8, 2003 | 03:48 PM
stephenlc's Avatar
Well I don't know what happen to the guy he has not e-mailed me back. He just sent me pictures, and has not gotten back to me. Maybe on vacation.
Old Dec 9, 2003 | 05:40 AM
Thaniel's Avatar
No worries there. I am putting a maxima engine into a RWD car (mated to a z350 transmission). It is actually there already but I had to do some hacking on the oil pan to install the starter. The VQ30DET oil pan might make it a cleaner installation. It is hard to tell for sure as I don't have many pics of that engine.
Old Dec 9, 2003 | 06:09 AM
DA-MAX's Avatar
heh, just saw your sig....you're a FREAK!!! Good luck with the swap
Old Dec 9, 2003 | 08:02 AM
stephenlc's Avatar
RX-7 man that thing is going to kick ***. I was thinking about doing th same thing but I don't have the space to do it in.
Here are the pictures you wanted:
http://www.turbo-maxima.com/vq30det/pictures.htm
Old Dec 9, 2003 | 08:08 AM
DA-MAX's Avatar
is it really a distributor ignition?? or just DIS with remote mounted coils(not sure of proper name) maybe??
Old Dec 9, 2003 | 09:27 AM
Thaniel's Avatar
Thanks for the pics. Yah I think the rx-7 will be cool when it's done. The Rx-7 I drive to work has 145hp where the maxima engine has 222hp. If that's not enought then I'll probably supercharge it.
I think the DET still has distributorless ignition. The wires I see in the pictures are the throttle cables and 2 vacume lines. I've yet to get a look at the engine without that stupid plastic cover over the engine. I'm also still looking for a pic of the flywheel side of the engine. The VQ's in the pathy's the starter is on the pasenger side. On the 350z it is on the driver side (maxima's its on the trans). Always more to learn I guess. (I used a pathy starter and custom cut the maxima oil pan).
Old Dec 9, 2003 | 11:43 AM
DA-MAX's Avatar
I looked at it again, think you're right!
Old Dec 9, 2003 | 11:46 AM
stephenlc's Avatar
Look at top picture I see the throttle cables all the way to the left. Then look at the bottom picture there is 4 lines going under the spark plug cover, are all of those vacuum lines.
Old Dec 9, 2003 | 12:01 PM
DA-MAX's Avatar
no hes right its the throttle cable...it comes out the right side, snakes under the valve cover and connects to the TB(like you see in pic #1) plus you can see the little "spool" thing where the cable originates on the right side of the car which is the driver side overseas
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
BassAddictJ
Aug 4, 2015 11:38 AM
