got the 300Z injectors whats the Base FP set at? 30PSI, 29, 20PSI
Old Dec 3, 2003 | 03:35 PM
JAY25's Avatar
I am about to install the vortech SFMU. I got the 300Z injectors.
I need to set my base FP to what?
I seen all types of numbers floating around. Can someone please post the correct FP so I dont drown my replacement motor w/fuel.
Old Dec 3, 2003 | 04:45 PM
Requin6's Avatar
i have mine set to factory spec...
with the vacuum line off of the regulator its set at 43.5psi. which when you put the vaccum back on it goes to 32-33ish at idle.
since you are running a different fuel setup then i am, i am not sure this same logic applies to you. but i hope that helps anyway.
--Paul
Old Dec 3, 2003 | 07:33 PM
KMax2988's Avatar
When I asked Mardi if 34psi was right awhile back, he didn't tell me I was wrong. I am also gettin ready to put Z 370's in, well actually Silvia injectors from Japan but same thing. I am going to be using a 3:1 disk in my FMU along with a FPR for base adjustment. This is one thing I am a little confused on as well though.
Old Dec 4, 2003 | 07:56 AM
Stephen Max's Avatar
There are three operating scenarios that must be addressed when converting to the larger injectors.
1. The first scenario is open loop operation and in NA mode (not boosting). In this case the ecu is relying on predetermined fuel mapping referenced to maf voltage (i.e. air flow) and throttle position (i.e. engine load) and is ignoring O2 sensor information. Examples of this operating regime are when the engine is cold right after startup, or when going WOT in an unboosted car.
Now, a 370 cc/min injector delivers 54% more fuel per pulse width than a 240 cc/min injector, for a given fuel pressure. Fuel delivery for a steady, imcompressible, lossless flow is proportional to the square root of the change in fuel pressure, so to bring fuel delivery down to something close to what the 240's give at a particular injector pulse width, you need to reduce fuel pressure from 34 psi down to about 27 psi. I believe Mardigrasmax mentioned adjusting down to 26 psi in one of his posts.
2. The second scenario is partial throttle operation where you are in a closed loop NA mode with the afr controlled by the ecu based on O2 sensor information. The ecu is capable of learning the 370 cc/min injectors and adjusting afr based on O2 sensor information with the help of the lowered base fuel pressure.
3. The third scenario is open loop, boosted operation. In this case, up to a certain power level (350 bhp), the ecu could adequately control the afr with fuel maps referenced to air flow measurement from the maf and based on a 1:1 increase in fuel pressure provided by the oem fpr, BUT with the caveat that the afr will be too high for safe boosted operation.
If you are below the 350 bph limit that the A32 maf can handle, then the afr can be lowered by raising the fuel pressure an appropriate amount by means of an fmu with more than a 1:1 rise rate, or by increasing the injector pulse width (i.e. duty cycle) with an air flow converter (safc). If you are above 350 bhp, then you have maxed out the maf and the injectors are already at maximum duty cycle and the only means to adjust afr downward is to increase fuel flow by increasing fuel pressure with the fmu.
Old Dec 4, 2003 | 09:22 AM
JAY25's Avatar
thanks alot 27PSI it is then
Old Dec 4, 2003 | 09:25 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Stephen
Now THAT needs to be stickied somewhere. Very well said!
Old Dec 4, 2003 | 09:35 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Holy moley...please sticky this man's post!
EDIT-- Doh! Icy beat me to that request...
Old Dec 4, 2003 | 09:52 AM
ejj's Avatar
ejj
Mine's set at 26ish psi. I haven't dyno'ed yet, but my EGT and A/F guage (only useful at idle) are both happy. Car feels and pulls fine.
Old Dec 4, 2003 | 03:37 PM
Bags's Avatar
VG Ridah's Biatch Hoe
how is everythign going?
Old Dec 4, 2003 | 06:51 PM
|Bijan|'s Avatar
UCF Lexus
27psiMaxima....
Old Dec 5, 2003 | 03:45 AM
JAY25's Avatar
Update:
I finally got done today, fired her up and she woke up very fast and no black smoke or anything. If anything I believe the FP might be quiet low. The car did not blow smoke or stutter I thought it did since the 370s are a bit larger. Today I may install a apexi electronic FP gauge and see what it reads.
Maxboy23
55
May 1, 2025 06:09 PM
9aj9
Apr 5, 2020 12:11 AM
gustavison
Oct 4, 2015 06:50 PM
carid
Sep 17, 2015 05:00 AM
