"You'll blow the welds on your intake manifold"
Old Dec 28, 2003 | 03:01 AM
hlh0501's Avatar
so fast and furious was right..
Old Dec 28, 2003 | 05:53 AM
MardiGrasMax's Avatar
FOK!
Nitrous backfire?
Old Dec 28, 2003 | 06:34 AM
CullenJ76's Avatar
OMG! hope everything works out hal
Old Dec 28, 2003 | 07:36 AM
CiViC KiLLeR's Avatar
Dang that looks bad hope everthing works out.
Old Dec 28, 2003 | 07:41 AM
hlh0501's Avatar
yes this hood is latched securely closed.
wtb: cf hood.
bottom:
mardigras, you're quick. also can't really see it in the other pic, the intake manif. gasket or whatnot blew out from under the mevi too. every charge pipe I had blew off including the IC ones behind the bumper, the IAC hose blew off off(clamped), MAF let go, etc.
cullen, you missed all this fun last night down at 11th. lets just say I put on one heck of a show
for anyone who cares: motor seems fine.. car should run later today when I get myself in the garage.
Old Dec 28, 2003 | 07:54 AM
CullenJ76's Avatar
haven't been to 11th or 13th in a LONG while.
you have to check your skivveys for stains after that one?
bet that **** was loud
Old Dec 28, 2003 | 08:36 AM
stephenlc's Avatar
What kind of shot were you running?
Old Dec 28, 2003 | 09:22 AM
Fezzik's Avatar
DANG HAL. If you're saying u'll be running again soon must not have been as bad as it looks in the pictures. I gotta hit 11th or 13th Street up sometime
Old Dec 28, 2003 | 10:36 AM
That is good it was just the manifold and not the motor. Good luck getting it all fixed.
Old Dec 28, 2003 | 11:12 AM
Conrad283's Avatar
I need a truck
Oh man, pics don't work sounds bad
Old Dec 28, 2003 | 12:00 PM
Jr'sMaxima's Avatar
Wow........that had to have been a really loud bang! Hope everything works out.
Old Dec 28, 2003 | 02:22 PM
redstradic's Avatar
that shows you i have no clue about motors. the pictures look bad and it bent your hood like that, but yet you will have it drivable by today!
Old Dec 28, 2003 | 04:27 PM
subs1000w's Avatar
i know i guy with a 306 mustang. he was running a wet 150 shot and the same thing happed although his intake didnt break it just blew the freeze plugs, vacume hoses and all the intake hoses apart. he thinks fuel puddled in the bottom of the maniphold and a spark got up in there and ignited it. very scary stuff
Old Dec 28, 2003 | 06:55 PM
MrGone's Avatar
thats because you shouldnt run wet shots on 5.0 mustangs, the fuel puddles in the intake runners and BAM!
why do you think dry shots are so popular with them?
Old Dec 29, 2003 | 08:50 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Actually, the NX kit has never had any problems with puddling in the 5.0L or 4.6L GT engines...
I have friends that run that kit every day (silly bastards) with no damage at all.
Old Dec 29, 2003 | 09:22 AM
Sooner or later...
Old Dec 29, 2003 | 09:51 AM
hlh0501's Avatar
couple more if anyone cares
Old Dec 29, 2003 | 10:02 AM
Dreizehn's Avatar
Is that coolant in the intake?
Was this a fuel puddling issue? Sorry I haven't been following too close...
Old Dec 29, 2003 | 10:03 AM
C MAX's Avatar
Originally Posted by MardiGrasMax
FOK!
Nitrous backfire?
yo sorry to hear about your car i look forward to exchanging some good car stories soon. i just dropped about 14,000 into my max it will be ready soon hopefully as fast as yours LOL.
dmontzsta's Avatar
Ford Only.
This is crazy stuff dude. That sucks that you damaged some prime aftermarket parts, CF hood, MEVI, etc...
Old Dec 29, 2003 | 10:31 AM
hlh0501's Avatar
it was purely driver error closely related to nitrous (its a NX wet setup)
and yes that is coolant sitting in the busted MEVI, but it that is from the destroyed radiator thanks to shrapnel from the mevi, maf, pipes, hood etc, all which blew into my 1mo old radiator.
valves appear visually fine, and no af in the oil.. so I think the motor will be ok. cross your fingers
Old Dec 29, 2003 | 01:27 PM
desertmaxima's Avatar
What sucks even worse is that it was an MEVI, you guys know how hard it is to get those in.
Old Dec 29, 2003 | 03:17 PM
CullenJ76's Avatar
not that hard anymore, but getting JUST the cover will be.
Old Dec 29, 2003 | 04:13 PM
JAY25's Avatar
Now you and the mad Scietist are going to have sit there and rip apart the block and replace the piston rings you burnt
What were you doing when that happened?
Got your PM will get you them Jpegs!
Old Dec 29, 2003 | 11:53 PM
ABK's Avatar
ABK
damn I seen a guy crack his intake matifold on dsm with his 20g that thing was pretty loud, I could imagine how loud that thing had to be!!!
Old Dec 30, 2003 | 10:28 AM
luckee2bhere's Avatar
Originally Posted by C MAX
i just dropped about 14,000 into my max .
tg
jebus! thats a healthy wad!
Old Jan 1, 2004 | 01:13 AM
HitManSE's Avatar
ouch is right. Goodluck man.
Old Jan 1, 2004 | 02:37 PM
michaelnyden's Avatar
what kinda shot were you runnin when you did this?
Old Jan 1, 2004 | 03:51 PM
hlh0501's Avatar
What I always run...
just too early.
Old Jan 1, 2004 | 05:31 PM
|Bijan|'s Avatar
UCF Lexus
Ouch -
RULE # 50!!
Hope you get that up and runnin soon man.
Old Jan 1, 2004 | 05:34 PM
Aaron92SE's Avatar
NWP Engineering.com
just too early.
Oh, I was about to ask exactly how it was driver error, so that we could all learn from your mistake. But it sounds like you simply sprayed too early in a certain gear. Was that the only reason you think?
Old Jan 1, 2004 | 09:25 PM
hlh0501's Avatar
yep, split second of spray - too early. it was at 8.7psi when it blew, so def not that.
I have put 10+ bottles at 10+psi on this exact setup with no problems.
got all the junk taken care of, hood for 65$ (and I get free painting), radiator 75$, maf 30$..
Old Jan 1, 2004 | 10:06 PM
(bijan gxe) That is some funny ****!!!!!!!! Do you mind if I print that out and show some friends?
Old Jan 2, 2004 | 07:39 AM
stephenlc's Avatar
Sprayed in first gear?
Old Jan 2, 2004 | 07:59 AM
plurco's Avatar
I am sure it would not be nearly as funny if it were your car
Old Jan 2, 2004 | 09:19 AM
Prolly to low in the rpm range.
Ive sprayed on the hole with slicks and never had a problem.
Hal, I guess you didnt have an RPM window switch?
Old Jan 2, 2004 | 09:24 AM
Blu's Avatar
Blu
the tits
Im sure it was a higher gear. 1st gear can be sprayed out of the hole without problems. Its the taller gears that you have to be careful with that don't wind out so quick...
Old Jan 2, 2004 | 10:10 AM
|Bijan|'s Avatar
UCF Lexus
CivicKiller - hell nah I dont care....I didnt make it
Those F&F pointers = funny as hell
Hal blowin his mevi = not funny
coincidence.....maybe
Old Jan 2, 2004 | 10:14 AM
stephenlc's Avatar
Why is spraying in too low an rpm bad? Is that bad in a gear other than first?
Old Jan 2, 2004 | 10:18 AM
hlh0501's Avatar
I left a parking lot headed home to garage the max until it's gone. I normally NEVER show off, I pull up with the car almost idling in - in hopes to get some races haha. This was my last time the car would be out, so I figured I'd show off just once. I pulled out (with slicks) and gunned it in 1st gear - that gear is WICKED... then trouble came - 2nd gear. I let it sit, It got stuck at too low of rpm's , so the car wouldn't move and for the split second that it saw spray it created insane TQ and couldn't move. BAM.
The car gets engulfed by one giant flame (Seen from under the hood, out the rear view mirror etc). Traffic on all 4 lanes stops bc they can't see 100feet ahead bc of the smoke and I steer it over onto the sidewalk and jump and run. People run up with fire extinguishers but luckily nothing was on fire. Then the couple hour wait began for the tow truck, IN THE GHETTO in the middle of the morning.
No RPM window switch, although now I'm def a believer! haha
on a side note, Ijust picked up a new car and am getting real tempted to keep the max now haha.. SP67 is looking sooo good!
