fuel management
fuel management
I think I have decieded on my set up...now I need to figure out the proper fuel management.....I am going with the V2 CAI set up, with A32 MAF, and 370cc injectors. What am I going to need on the fuel side to make this system run effectively and efficiently? I have a 98 so if I am correct the JWT ECU is not an option for me (let me know if I am wrong)...please let me know what kinda fuel management setup you guys would run with this setup. Thanks
Carson
Carson
Carson
Carson
http://forums.maxima.org/showthread.php?t=270939
ok I read the whole thread....and what I get from this, is that by using the 370mm Z injectors and a Z32 MAF then you dont really need any further fuel management, other than possibly a SAFC....though it not really proven yet. Has any one proven this set up yet using the stock ecu?
My experience running the 370's, Z32 maf sensor and oem A32 ecu is that the car ran perfectly in partial throttle situations. I went to WOT up to about 9 psi and detected no detonation and egt's were around 1450F, which is pretty normal for my car. That was with a 5 speed ecu, which I only had in the car for that one drive.
Later, I put in my original auto ecu and drove it like that for about a week. It drove perfectly at partial throttle but would ping at WOT after the engine was heat soaked. I'm going to put the oem 5 speed ecu back in and see if the pinging was an auto ecu issue or due to heat soak.
At any rate, this setup definitely needs some dyno tuning for safety's sake and a means to adjust the afr at WOT.
Also, from what I've read in the forums, you can run a JWT ecu in a 97-98 but you get a CEL. I don't know what code the ecu throws, though.
Originally Posted by Stephen Max
What do you mean by proven? If you mean a dyno session where afr was monitored, the answer is no. I might be doing that in the not too distant future, though. I'm waiting for a Fidanza flywheel to install before I dyno again.
I will look into the JWT ECU a little more but this sound promising, since my car is manual, so I already have the 5 speed ecu....and you said that you had no problems at partial throttle...did you ever go WOT? I have read in past post that people were having some bogging at WOT with this set up....and if I did get bogging, I could probably fix this with a AFC right?
I didn't experience bogging at WOT, rather the opposite problem. That is, indications of leanness.
I don't mean to be disrespectful, but if you reread what I wrote, you will see "WOT" a couple of times.
And also with this setup I am assuming that you are running a walbro fuel pump?
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
