SC belt question
Old Jan 8, 2004 | 02:16 PM
LatinMax's Avatar
SC belt question
OK as most of you know I am going to run a 2.875" pulley on my V2 SC.
Gates belt is K060703 &
Gatorback belt is a 4060703 but it is suggested to go with 4060700 to really avoid a slipping belt.
The problem isi went to Auto Zone to get the 4060700 belt and all they carry is 4060705 or 4060695.
Simple question which one do I get? OR
Do I need to get the 4060700 belt? and where?
Old Jan 8, 2004 | 03:59 PM
maxlinegtr's Avatar
Get the K60703. That is what I have. I would not go with any other unless its suggested. Look around for other places,cuz it took me awhile to locate the proper belt. Good Luck.
Old Jan 8, 2004 | 04:26 PM
LatinMax's Avatar
I am trying to avoid going with Gates since the slip easier. Can I go with the 695 or will it be too small to fit?
Old Jan 8, 2004 | 05:29 PM
maxlinegtr's Avatar
I beleive it has to have 6 ribs in the belt and then the length of it. (i.e. K060703 is 6 ribs 7 ft 3 inches..) its something like that. you get the idea. compare the the inside and the length.
Old Jan 8, 2004 | 05:54 PM
JAY25's Avatar
go to another autozone thats not as busy. Some clerks are just plain lazy fcks. Ask the clerk to go the back and grab the next shorter belt under that one. Part number may be totally different.
Or buy a gates belt, keep the receipt and then go to autozone and grab a gater back thats as close that size as possible.
Old Jan 8, 2004 | 06:09 PM
maxlinegtr's Avatar
Alot of the time the store is not goin to have it. patience and alot of phone calls are needed. I spent almost a whole day lookin for the right belt...surprising pep boys, kragen, even autozone does not have it. try NAPA or some low pro auto store that is not a franchise, they might have it. I went to Big O auto parts doubt u even heard of it.
Old Jan 9, 2004 | 03:59 AM
GoldenGlory
does it really matter what name brand you get?
i forgot what belt i got..but its been on 11k miles..and im changin it now..because it has dry rotted... due to the abuse it took from this past summer.
no slipping no hopping no problems...
so whats the big difference in belts?
Old Jan 9, 2004 | 05:28 AM
ejj's Avatar
ejj
Goodyear may not make a 700 belt. I couldn't find one locally to save my life.
LatinMax, I would say get the 695. 8/10's of an inch difference isn't really that much, and shouldn't be a problem.
Old Jan 9, 2004 | 08:42 AM
LatinMax's Avatar
Ya Goodyear did not carry the belt either.
The reason I want to go with the Gatorback belt is that it will not slip even when a little loose. (something about the cross cut in it.
I don't think the 700 is made. I may just have to try the 695.
I just would hate to have to pull it all out because the belt does not fit.
Who is running the 2.875 pulley with the V2? What belt are you running and how tight was it going on?
Old Jan 9, 2004 | 09:46 AM
C MAX's Avatar
i know this doesn't answer your question.... but i was looking in the jc whitney catalog and they have this adjustable emergency replacment belt that you dont have to take off or adjust the pulley... just wrap it
around and snap it on.. in case the s/c belt breaks while on a trip.
i think that would be handy cause you can change it quick then replace when you get home
Old Jan 10, 2004 | 06:35 PM
LatinMax's Avatar
Can Anyone help?
Old Jan 11, 2004 | 01:04 PM
LatinMax's Avatar
come on someone has to know.
Old Jan 11, 2004 | 09:42 PM
sx7r's Avatar
howdy pardner
Old Jan 11, 2004 | 10:01 PM
iansw's Avatar
4060703 is your best bet according to this post (I bumped it up in the forum)
http://forums.maxima.org/showthread.php?t=213692&page=1
Old Jan 11, 2004 | 10:10 PM
LatinMax's Avatar
But on the Gator Back belts should I go with the 4060695 Shorter
or 4060705 longer.
From the above post it says that 4060703 is a little too long for my pulley and that you can get a little more than a 90 degree turn so will there be room to go with the 4060695?
Old Jan 14, 2004 | 01:53 PM
LatinMax's Avatar
I have now been told that htis belt id NOT made. Is there room to go with the 695 or do I need to go longer ang get the 705.
Help I need to know.
Old Jan 15, 2004 | 08:40 AM
ejj's Avatar
ejj
10chars.......
Old Jan 15, 2004 | 05:09 PM
LatinMax's Avatar
Sorry ejj....I misse that post. I will go with the 695. I will let everyone know what comes of it.
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
Socalstillen
Sep 26, 2015 12:01 PM
