Whats better, manual or auto turbo?
Old Jan 12, 2004 | 06:50 PM
PEARLYI30's Avatar
I have a auto 1998 I30 and im getting a turbo this summer. Is it worth it to get the manual conversion or just stick with the auto. I do not want to change that many things over with my engine if it's not even gonna make a big difference, and I see on maxima.org alot of people with auto turbo's and I30's .
Old Jan 12, 2004 | 08:08 PM
subs1000w's Avatar
this should answer most of your questions
http://forums.maxima.org/showthread.php?t=276852
Old Jan 13, 2004 | 07:53 AM
ptatohed's Avatar
Licensed to Spell
:o)
Someone correct me if I am wrong but, from my understanding, auto turbos are faster than stick shift turbos. This is because when you shift in a stick shift, you need to take your foot off the gas. There is this guy on the Supra forum who has a stick TT and an auto TT. He says his auto wins hands down everytime at the track.
Old Jan 13, 2004 | 08:28 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
no....they can be faster, but in genreal usually aren't(stock tranny v. stock tranny) if HP is same, 5spd with decent driver will win 99% of the time
Old Jan 13, 2004 | 08:32 AM
Stephen Max's Avatar
If you're good, you don't let all the way off the gas when you shift. Just enough to rev match the gear you're going into.
Old Jan 13, 2004 | 09:07 AM
hlh0501's Avatar
built auto > manual
it will maintain full boost through a shift, not to mention shifting faster anyways. also you can build boost at the line w/out twostep or antilag (which is possible in a manual , just not easy and terrible on the clutch) and typically more consistent & perfect launches
now where you can find a good built auto tranny for the maxima? Don't know. Someone needs to talk SP into making a SP400 for the max haha
for fun driving, manual will always reign!
Old Jan 13, 2004 | 10:20 AM
C MAX's Avatar
thats right because once you press the clutch you lose boost.
a auto wont lose boost.. but it all depends on the driver and what is actually in both cars....
Old Jan 13, 2004 | 11:58 AM
I never thought about it in the context of shifting before, but supercharger boost is engine rpm dependent, turbo boost is throttle position dependent. So you don't lose boost when you manually shift a SC'd car.
Old Jan 13, 2004 | 12:08 PM
subs1000w's Avatar
the blow off valve isnt just to make a cool sound its to help reduce the turbo despool between shifts
and of course i agree with the fact that a $$$well biult auto$$$ will beat a manual in a high hp car but i would never drive it because it would be
SO DA$M BORING TO DRIVE
Old Jan 13, 2004 | 09:02 PM
JAY25's Avatar
Manual hands down until someone ***** a bullit proof tranny for our cars. People that play alot here on the org are manuals. What I mean by play is that they hang out on private property etc..making racing videos at night. Its true an auto vehicle has the advantage. I dont think that will apply for a maxima. Why would you want that heavy clunk of metal in the car. Any of you ever try to pick up an auto tranny ? that **** is heavy! very heavy. I prefer a manual tranny with a Quaife or LSD over an auto tranny any day.
Old Jan 13, 2004 | 11:31 PM
Nismo87SE's Avatar
Auto would own a 5spd given the right setup (TC stall speed, gear ratio). Once you pass the 300whp mark the auto definitly has the edge.
Old Jan 14, 2004 | 06:35 AM
stephenlc's Avatar
Doesn't the throttleplate stay open in the auto maximas? I know it closes every time the transmission shifts on a supra. Wouldn't that keep the boost up?
Old Jan 14, 2004 | 06:39 AM
subs1000w's Avatar
if you hold the skinny pedal on the floor the throtle plate is open so yes but you can also hold thethrottle plate open all the time on a manual to i believe its called power shifting
Old Jan 16, 2004 | 07:44 AM
C MAX's Avatar
Your So Right
Old Jan 16, 2004 | 07:46 AM
C MAX's Avatar
JUST WHAT IVE BEEN TRYING TO SAY ALL ALONG.. THANK YOU WELL PUT...
Old Jan 16, 2004 | 07:52 AM
Yeah, I've always felt that arguments that agreed with mine were well put, too.
Old Jan 16, 2004 | 08:22 AM
subs1000w's Avatar
id like to see someone who knows HOW TO SHIFT A MANUAL AT THE TRACK and there are a few here that do, to run there car with the stick and then put a biult auto in and run it with that. i bet the numbers would be so close that it would be cheaper to add more hp to the car and keep it a stick than to biult a $3000 auto
i mean how much extra power would the manual need to make up for the slightly slower shifting probobly only 20 or 30 maybe even less than that
Old Jan 16, 2004 | 09:06 AM
C MAX's Avatar
no its the other way around.. it is us autotragic drivers that have to play catch up.. i think we have to spend more money to keep up with a five speed, but once we do... watch out..
Old Jan 16, 2004 | 09:37 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
NRH has a pretty stout custom auto for under $4K...with LSD.
Old Jan 18, 2004 | 10:46 PM
PEARLYI30's Avatar
who is nrh?
Old Jan 18, 2004 | 10:50 PM
|Bijan|'s Avatar
UCF Lexus
You need to talk to JaimeCBR900 - he knows ALL about torqing up auto trannys
Old Jan 19, 2004 | 07:33 AM
OT n00bs FTMFCSL
I believe he used NRH for parts as well. NRH is in Jessup, MD...build high quality, high performance transmissions. Do a search here on the .org (if you can) and look for their name. I might have a site saved somewhere about them. If so, I'll post the info...
http://forums.maxima.org/showthread....H+transmission
Old Jan 19, 2004 | 02:33 PM
Conrad283's Avatar
I need a truck
Leventen.com
Old Jan 19, 2004 | 03:53 PM
CiViC KiLLeR's Avatar
(Conrad283) levelten trans SUCK. Thay maybe a little stronger than stock but not much. The beat place that bulletproofs trans is NRH thay are the best for a maxima.
Old Jan 19, 2004 | 05:33 PM
mayhemI30's Avatar
"I'm running with scissors!"
i had an built auto in my old i30 (3100 stall, posi, stage 3 vb mod, etc, ect) but i sold it. anyways i raced him from a stop he got owned bad. if you are performance oriented 5-speed baby. if not go auto. whatever you do just go fast.............................................. ..............................
5 speed all the way!!!!
Old Jan 20, 2004 | 01:34 PM
Redmax's Avatar
Redlinemax Owner
I have an NRH Auto Tranny and will be boosting over 300whp by tomorrow and less just say this thing shifts effortlessly!!!! It Is Da Bomb!!!! The only down fall is the 3500 to 3700. price tag. It has full 100% posi Traction! The best thing is Rob warranties the tranny knowing full well that the thing is going to be beat on. as a matter of fact he wants you to beat on it.
AUTO TRANNIES OWN STICK ANYDAY!!!!!!
Old Jan 20, 2004 | 01:44 PM
Shadow's Avatar
Silly question, but if I had a spare auto, I could just send it to Rob at NRH? I know shipping would cost, but that's no huge deal. I mean, he doesn't need the car for any of his work does he? And what is turnaround time?
Old Jan 20, 2004 | 02:00 PM
DA-MAX's Avatar
I'll definently vouch for Coreys tranny...after riding and test driving the car after this weekends 3 day re/install extravaganza I will say NRH auo trannys OWN!!! the 1-2 shift is simply flawless, smooth and quick as a knife through butter...I have a few videos, but need a host tonight should be fun
Old Jan 20, 2004 | 02:34 PM
Redmax's Avatar
Redlinemax Owner
Turn around is usually 2 weeks on trannies and no he doesnt need the car for anything
Addae we are confirmed for 6pm tomorrow
Old Jan 21, 2004 | 09:36 AM
OT n00bs FTMFCSL
Yeah, what he said. The price more than justifies what you get (both physically, and in the form of his warranty). This is the ultimate auto transmission for our Maximas...
Old Jan 28, 2004 | 06:26 PM
LatinMax's Avatar
I get mine in the next week.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
BobTX10
Oct 7, 2015 08:43 AM
