Higher Octane on turbo?
Doesnt really apply to just turbos. Higher octane is not better performance gas, its basically gas that has the ability to deter knock more.
So anything that helps deter knock more allows you to push the boost higher and get more out of the car.
Dixit
Dixit
Honestly, you'd be smarter to spend $420 on an Aquamist water injection system.
Instead of paying $5+/gallon for 100+octane, you can mix in a little alcohol to prevent detonation like high octane gas AND get inter-cylinder cooling like an intercooler.
Plus, you can set it to turn on at a certain PSI, so you only use it when you need it.
IMHO, there is NO better bang-for-your-buck then an Aquamist WIS and anyone who is FI with stock CR is crazy for not having this AWESOME technology aboard. WRC guys swear by this setup and they run high boost for extended periods of time. Even their ECUs are programmed to work with WI, since they can get more timing AND boost.
Not sure how you would activate it, since the basic system uses a MAP sensor, but you *SHOULD* be able to manually turn it on via a switch. So, just put it inline with the N20 trigger switch?
Aquamist would be useful for the octane bump, but the N20 will definitely be superior on inter-cylinder cooling.
Originally Posted by SonicDust187
Can Aquamist be used with a nitrous system (wet kit)?
would it be possible to use the stock windshield washer bottle to hold water for the system or would you need somthing bigger
any idea on how many gallons of water per hour it sprays i guess that would be dependent on what size jet you use and how often your in boost but a general idea would be nice im very interested in this as an alternative to an intercooler but if it uses more than 1 gallon of water per hour i dont think it would be conveniant
Originally Posted by subs1000w
where do you mount the water jet I assume right before the throttle body but i dont know
Per Aquamist, you should mount it as close to the IC discharge end as possible.
Now that I think about it, the rally car I work on has a boss welded into the elbow exiting the IC to be tapped for WI.
The longer the path, the more water that will be vaporized thus heat that will be absorbed.
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
