I've sprouted another gauge
Well, not me. My car.
It's the analogAFR gauge supplied by Innovate for use with the LM-1 wideband O2 unit. It's made by Westach. Too bad I couldn't keep the Autometer Phantom motif going. Oh well.
Idling very nicely at stoich.
I'll be getting a SC soon, do you think this could be used in place of an EGT, or would you still suggest both. I can't really afford both so I've been debating which one to get.
Also I assume the gauge is still functional even when the Data logger isn't plugged in, right?
When you Data log, how do you compare the instantaneous AFR to a specific RPM?
Sorry about all the questions, but I'm curious.
I have the same thoughts
Originally Posted by jdmmax
kool is accurate?????
Icey: The needle hardly fluctuates at all when driving or idling. It does just the slightest bit, following the ecu's adjustment of the afr. The only time there is a wild fluctuation is when closing the throttle at an engine speed high enough that the fuel cutoff is activated. Then the needle swings way into the lean range until you give it gas again.
Max: Yes, you could use this instead of an EGT since it measures afr directly rather than indirectly like the EGT does. You have to have the LM-1 plugged in, since the LM-1 is what processes the signal from the O2 sensor and sends it along to the gauge. The LM-1 also controls the O2 sensor heater, so running without the LM-1 will result in a carbonized O2 sensor in very short order.
To log data against rpm, you get an auxiliary cable that has an rpm converter built into it. It plugs into the LM-1. Then you just tap in to an appropriate tach signal (such as the tach wire at the ecu that an SAFC uses). The aux cable has provisions for four other inputs. I'm going to log boost pressure (with a 2 bar MAP sensor from a Grand National), TPS, MAF voltage, and intake air temperature.
Wow thanks for the info. That's pretty cool. Seems a little inconvenient though for daily use. Where do you put the LM unit while driving around? Will the unit turn on with the ignition? Seems like you would have to turn it on every time you get in your car. Still, being able to data log that info is awesome, and would allow you to tinker and effectively know the results. I can see it being very useful even if you didn't use it daily. How much did the gauge cost ya?
The LM-1 costs $350, including the sensor. I found a dealer selling units for $330 on ebay, though. The gauge and its cable cost about $70, and the auxiliary cable needed for rpm and other sensor input is another $100.
OK that sounds fairly user friendly. It's nice to hear you can leave it on all the time and have it turn on with the car. Even adding a relay is no big deal really if you want the extra security. In fact you could probably wire the relay so the LM is only on when the engine is running. Prices aren't bad either. 100 seems a little on the steep side for the accessory cable, but considering what it can do it's worth it. So your talking around 500 bucks for the package. Guess that's not too bad if you virtually eliminate the need to dyno.
Stephen Max-My sister lives in Austin. I'm coming out at the end of April to go to my cousin's wedding. If I came in early do you think that i could check w/ your setup. I'm really interesed in being able to tune in realtime instead of on a dyno sled.
are you able to adjust fp with the LM-1? What kind of fpr do you have, and do you think it would be compatible with the jwt ecu program?
Steve
Steve
Steve
Steve
Let me know when you're in Austin.
220k+ A32
18
09-22-2015 11:39 AM
RWCreative
09-21-2015 11:01 AM
