What Size Turbo For VQ35????
I'm going to be doing an engine swapping project soon and custom turbo setup. I would appreciate it if you turbo guru's could help me in my process of my project. Which turbo is better suited for a VQ35 for street and track use, A t04e or a 60-1? Thanks in advanvce.
*No Flames Please*
*No Flames Please*
*No Flames Please*
*No Flames Please*
Originally Posted by pimpjuice
I am running a TO4E/60-1 hybrid.
what you have is a T4/60-1
you could also have a T4/TO4E
Yes sir, you are correct... my mistake.
I see full boost at 4K. One of these days I'll have to post a picture of my boost controller so you can see the boost curve in each gear.
Dynos are here: www.total-x.net
subs1000w, What turbo would you rather have on your 2k2?
the first youll get a faster spool because of the smaller turbine housing but the later one will be less restrictive for better topend
http://store.yahoo.com/cheapturbo/gart0t4w70tu.html
http://store.yahoo.com/cheapturbo/gart0t4w84ar.html
pimpjuice The dyno graph wont show up on your site.
subs1000w: With the diffrent A/R for the 60-1, what rpm would the 60-1 with 70 A/R be fully boosted compared to the 84A/R?
My bad, I didn't click the Read More Icon.
Pimpjuice,What Psi were you running with for the Dyno's. Did you upgrade to the 3inch cat-back and fix the VI? If so What are your numbers now?
Matt, Id be slightly concerned that you have it tuned at 13:1 a/f ratio. That is a bit lean to be running on a boosted car. Bring that lower to at least 12.5. Some like to stay within the 11.5-12.5:1 range. 13 is pushing it.
Also what elevation are you at? Cause the corrected numbers are a good bit higher. Im sure you know you are not supposed to altitude correct the turbo dynos. You can still temp/pressure correct them.
Dixit
Dixit
Dixit
Dixit
At the time I got the dynos I just had the guy print me out a copy of my dyno. I know now that I am to use uncorrected numbers instead.
ho-humm...
*No Flames Please*
*No Flames Please*
Deac
Originally Posted by Deac
Deac
litch
123
Jan 4, 2024 07:01 PM
