Fuel pressure regulator advice
Hey Guys,
My fuel pressure regulator went out on my 2000 Maxima.
I figured I might as well get an aftermarket adjustable one.
I plan on eventually supercharging it, or at least getting an e-manage or something similar, so It should be a benefit to have an adjustable one at that point.
What do you guys recommend for a good aftermarket regulator?
Thanks.
Thanks.
Well if you dont plan on supercharging no point. Even if you get an eManage, no need for an aftermarket FPR unless you plan on upgrading the fuel pump to lower the base FP.
Other than that, most use either the SARD or AEM FPR. With either of those, you need to get the fuel rail fitting from http://www.sx7r.com/order.htm
Dixit
Dixit
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
