231whp/228tq
Old May 11, 2004 | 02:09 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
231whp/228tq
Oh man, I found my boost leak!
Went to dyno and had a couple of runs and every afc setting we tried, it would give the same a/f.
I have only been seeing about 5-6 lbs of boost and have been hearing a "screaming" noise. I thought that it was a belt slippage problem, but it isnt.
we hooked up a compressor to the charge piping and fed some air through it to determine if there was a boost leak and, viola! its coming out of the adapter that fits my IAT sensor into my AWAC.
I know now why I am running so rich and only made a 13.7 run two weeks ago.
I just need some epoxy to seal it up, anyone have any suggestions? Looking for something that will work at engine temps and wont melt the plastic housing.
I was also thinking about sealing over the epoxy with some silicone.
Thoughts?
Steve
Old May 11, 2004 | 02:10 PM
slimer's Avatar
Oh, and its a V2 with a 3.33" pulley
Old May 11, 2004 | 03:42 PM
stephenlc's Avatar
Get someone too weld it again, or maybe orange stuff.
Old May 11, 2004 | 04:38 PM
slimer's Avatar
it wasnt welded on in the first place.
i'm off to napa to go and see what sort of form-a-gasket, sealant and epoxy that they have
what is orange stuff?
Old May 11, 2004 | 08:39 PM
stephenlc's Avatar
They use it on exhuast leaks. and around gaskets to seal leaks.
Old May 11, 2004 | 08:42 PM
iansw's Avatar
Wow - 13.7 on 231whp?
That's a pretty amazing run.
By my calculations you should be at about 14.3-14.5 on a good run with only that much power.
Old May 11, 2004 | 09:19 PM
slimer's Avatar
ill see if i30tmiked has our timeslip.
we ran each other at byron
when i was manually shifting, accidentally popped it into N out of 2nd and then shifted 2 third and went 13.7
Old May 11, 2004 | 10:02 PM
meccanoble's Avatar
Sports Button FTW
wow and it was an auto too
Old May 11, 2004 | 10:04 PM
iansw's Avatar
I'm not saying you're lying, I'm just saying that's amazing!
I was at 273hp and 245tq when I was Auto and pulled a 14.7 as my best time. Granted, with a heavy stereo in the trunk and a malfunctioning MEVI....but still!
Old May 12, 2004 | 08:22 AM
slimer's Avatar
no, i was wrong ian, you were right.
it was 14.7
sorry
i fixed the boost leak last nite with that orange stuff. Its high temp rtv silicone sealer.
it looked to be holding up well this morning
im going to put another coat of it on tonite
Old May 12, 2004 | 08:43 AM
iansw's Avatar
OK - that makesm ore sense. Thought there was something wrong with me there for a sec. :gaptooth:
Old May 14, 2004 | 04:43 PM
Jer's Avatar
Jer
Woohoo! That makes me feel better about my car because I ran a 14.5 best on 5psi
Old May 15, 2004 | 06:50 AM
I30tMikeD's Avatar
I was like WTF!? You did not run any 13.7.......at least not when I was there. Hahahaha...I am not going to lie for you Steve
Old May 16, 2004 | 12:21 AM
vqman
yeah, I ran a 14.8 with 204whp and 218tq...
(stock)
-vq
