Cant get Bolts off
Old Jul 11, 2004 | 07:22 AM
matty's Avatar
Cant get Bolts off
Stand off Hex Head bolts off the back of the blower to replace belt...I put it all together and forgot to put the two M6 bolts in the holes by the Pulley...I put Locktyte on those hex heads on the back and now they wont come off...are those Two top M6's that important ?? or leaving them off a bad idea ??
I almost stripped out the Hex head on one of them cause its soo tyte...I cant get them off
-matt
Old Jul 11, 2004 | 12:32 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Use the allen wrenches in combo with a ratchet and a breaker bar
Old Jul 11, 2004 | 12:37 PM
matty's Avatar
I wanna know if those two top bolts by the pulley into the timing chain are "important".,..alot of s/c setups I have seen, they are missing
-matt
Old Jul 11, 2004 | 12:40 PM
Stephen Max's Avatar
-matt
I would use at least one. The one towards the front is the easier one to thread in or remove.
Old Jul 11, 2004 | 01:19 PM
matty's Avatar
i cant seem to get the blower back off of the plate...for the life of me...Im almost stripping out the hex head before the bolt even moves...
right currently I have the rear one in and was looking at it and figured out that one is going to be impossible to get in...I want to switch it to the front hole but may not be able to
-matt
Old Jul 11, 2004 | 02:35 PM
vortechpower's Avatar
You might want to try having 2 people hold the blower while you pull like hell. Thats what I have to do, my allen wrenches wind up looking like twizzlers when I am done. Good thing I got craftsman! If those bolts came off easy that wouldnt be a good thing now would it. Now quit your Biatching and take them bolsts off
Old Jul 11, 2004 | 03:00 PM
matty's Avatar
Cant Get Em...I heated them up with a tourch and still nothing !!! I guess I put too much locktyte on them and Ill have to do with only one of those top bolts in (the top back one) and try and get that threaded without fu**ing the threads up
id like to take the back one off and move it to the front hole
-matt
Old Jul 11, 2004 | 07:11 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
are you sure you have mm, cuz if u use sae it will just spin in there.
i got a set of xtra ones from stillen.
also, why did you use loc tite, i put anti sieze in mine for when the blower heats up
Old Jul 11, 2004 | 07:32 PM
matty's Avatar
Everyone told me use Lock Tight...even in the directions it stated that...
No there not spinning, there really tight, I had them out about a week ago...
-matt
Old Jul 12, 2004 | 08:06 AM
BlackCat's Avatar
RIP '98 Maxima SE
-matt
I took my 2 Allen wrenches with my blower and mounting plate to a local garage. They loosened the bolts for me with their air tool for nothing!
Old Jul 12, 2004 | 08:48 AM
maxlinegtr's Avatar
I had the same situation...my bolts are ptretty stripped also...I kinda used a hammer.. I used an L shaped allen key and just basically whack the key so that u would hear a crack meaning u broke the locktyte..u just have snap the locktyte loose. and it takes a awhile with patience. good luck matty. thanx for reminding me, i have to buy buy some new bolts.
Old Jul 12, 2004 | 08:59 AM
matty's Avatar
what size were your two allen wrenches... ??
Old Jul 12, 2004 | 09:50 AM
BlackCat's Avatar
RIP '98 Maxima SE
Actually I bought a whole set of Craftsman allen wrenches. I remember using only two wrenches for the mounting plate. I think the biggest one I used was the 5/16ths...can't remember what the other one was. Also I used Locktite 242 on the threads.
Old Jul 12, 2004 | 11:06 AM
matty's Avatar
no way there coming off...just went down to my macanic..I used the Red Locktyte and way to much of it...we dont wanna risk breaking the bolts
-matt
Old Jul 12, 2004 | 11:20 AM
JAY25's Avatar
You used the red ****? I feel your pain. I would not use loctite on those FHCS bolts that hold the blower to the plate hell sss naaah. You think thats bad. They get about that tight without the loctite. I just snug them with my hand and thats a wrap. When is time to change a belt or what ever the case may be, they are pretty hard to remove.
Guys dont use loctite on those allen bolts. Use loctite on the 10mm bolts that hold the SCer plate to the engine timing case. Thats fine to do that. And dont torque the bolts down either. Timing case is made out of alloy and will strip easily
Old Jul 12, 2004 | 12:06 PM
Chunger's Avatar
My other car is a Hybrid
Those allen head bolts are a real pain. I had a heck of a time removing mine the first time and actually stripped one on someone elses kit. Ended up drilling out the head and using a new bolt.
On my car, I think I actually used antisieze on those! I haven't had any problems YET. I would imagine it s/b safe to use some loctite by the head of the bolt only and not the threaded region at the end of the bolts... Those long bolts "twist" under torque and causing the problems removing them.
Old Jul 12, 2004 | 12:15 PM
BlackCat's Avatar
RIP '98 Maxima SE
-matt
Locktite 242 is the blue one. I have had no problems at all taking out the bolts with this stuff.
Old Jul 12, 2004 | 01:01 PM
matty's Avatar
Well I used the red stuff...Im F*cked...they wont come loose and im afraid to go breaking them. They ill have to drill and tap the actual blower...im an idiot
Old Jul 12, 2004 | 01:38 PM
BlackCat's Avatar
RIP '98 Maxima SE
Before you give up Matty check this out:
Easy Locktite Removal
We use a lot of Locktite at work: RC635 (Max. Strength Retaining), 290 (Adhesive/Sealant, Wicking), 242 (Threadlocker) and 7649 primer for 518 (Gasket Eliminator). Whenever we have to remove the stuff or break something free, we cringe! We've called Locktite and asked about solvents. They claim that none exist. Heat isn't always a good solution because you can warp or break castings.
Recently, just by luck, we spilled some methyl alcohol on a fitting which had Locktite on it. The alcohol softened and then dissolved the Locktite.
Try this before hauling out the blowtorch.
Sidney in NC
tech@fireflyballoons.net
http://www.guzzitech.com/LockTite-SC.html
Old Jul 12, 2004 | 01:45 PM
matty's Avatar
So regular rubbing alcohol or some other kind ??
Ill try and feed some in threw the cracks and let it sit over night...
-matt
Old Jul 12, 2004 | 01:47 PM
BlackCat's Avatar
RIP '98 Maxima SE
Here's the Locktite color chart for those newbies who haven't used it before. 242 Blue is the safest to use.
http://www.humvee.net/hid/misc/locktite.html
Old Jul 12, 2004 | 01:54 PM
BlackCat's Avatar
RIP '98 Maxima SE
-matt
Here is a writeup on methyl alcohol:
http://members.tripod.com/blackhaven22/methyl.htm
Old Jul 12, 2004 | 02:01 PM
matty's Avatar
Will it seap down onto the Locktyte past the bolt if I put a bit around the sides and wait over night ??
Old Jul 12, 2004 | 02:16 PM
BlackCat's Avatar
RIP '98 Maxima SE
Yeah, I would try that. Let us know tomorrow if that helps you out.
Old Jul 12, 2004 | 02:40 PM
matty's Avatar
Thanks for all the help...The only reason to take the blower off in the future is to go to a 2.87 pulley, or change the belt if it wears out...for now im fine with 1 of 2 of those top m6 bolts in, but thanks for the heads up..Ill keep it mind for later on
-matt
Old Jul 22, 2004 | 10:36 AM
BlackCat's Avatar
RIP '98 Maxima SE
-matt
Hey matty....any luck with the bolts?
Old Jul 22, 2004 | 10:41 AM
matty's Avatar
I just got back from vacation so ive been fadeing away from the blower situation..I have so much work to do to get this thing in...
Im going to leave the bolts since I already have a new belt on and ill worry about it when I need a belt...I will remember the recomendations, thanks
-matt
Old Jul 30, 2004 | 01:53 PM
maxlinegtr's Avatar
keep us posted matty
Old Aug 18, 2004 | 09:25 AM
C MAX's Avatar
-matt
matty if your still having a problem i just learned a new technique. i received my s/c back from vortech and the pulley bolt had a nut welded to the top of it. they said the bolt stripped and thets how they get them off the only problem is you have to get a another screw. stillen said you can get those bolts anywhere there just a basic screw. i made them saend me one next day at no charge though why should i waist my time for their mistake.i dont know why they make those holes so small when you need a lot of torque to get them off.
Old Aug 18, 2004 | 10:55 AM
matty's Avatar
No the ones that are have too much locktyte on them are the stand off bolts on the back of the plate that hold the blower to the plate...There Allen Keys
-matt
Old Aug 18, 2004 | 12:11 PM
C MAX's Avatar
-matt
yes exactly what im talking about the black screw allen type thing in the back that holds the blower. they welded a nut to the head and used a socket to get it off. i can take a pic if you need to see what im talking about. they stripped that little hole and thats how they do it they said.
Old Aug 18, 2004 | 12:27 PM
matty's Avatar
I understand now...well im most concerned that they dont break in the blower. Then I have a mess on my hands cuase will have to get the drilled out..>NOT FUN.....I took it down to my macanic and we tried but there is one that isnt budging, and we only tried the big ones, we havent even did the small ones yet..
Im going to leave it for down the road
-matt
Old Aug 18, 2004 | 05:10 PM
C MAX's Avatar
-matt
i doubt they would break those bolts are solid. stillen told me they use this technique all the time because they get a lot of jobs with stuck bolts.just weld on a nut and then you can air gun them off. they just dropped some weld on the inside corners of the nut.
Old Oct 31, 2004 | 07:19 PM
matty's Avatar
Well I had to take my blower off to get it rebuilt again cause Vortech messed it up on the rebuild...
Had to get the bolts off...all of except one so I needed to get a bolt welded on it and took it off with a 3/4in drive...DAM* i used too much locktight..take a look
the blower is off to vortech tomorrow
-matt
Old Nov 1, 2004 | 03:48 AM
C MAX's Avatar
-matt
no more lock-tite even with anti seize compund its still a b!tch to get off. good luck.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
