More question about Stillen FMU
Old Aug 26, 2004 | 03:35 PM
1MAX2NV's Avatar
Can the Stillen FMU work without having the OEM regulator in place? Would it able to hold the correct base pressure? I assume not. If not, what other adjustable base pressure FMU are out there? Cartech?
Old Aug 26, 2004 | 03:47 PM
Chunger's Avatar
My other car is a Hybrid
No... The Super FMU can, though.
I'm assuming you're talking about the Vortech FMU in the Stillen SC kit.
Old Aug 26, 2004 | 04:54 PM
Bags's Avatar
VG Ridah's Biatch Hoe
The cartech FMU is BETTER than the SFMU.
And the cartech FMU can adjust base pressure without the FPR.
Old Aug 27, 2004 | 05:54 AM
Stephen Max's Avatar
Sorry, Kirk, that is incorrect. The Cartech fmu is not able to adjust base fuel pressure. At least mine can't. The Vortech s-fmu can.
Old Aug 27, 2004 | 07:30 AM
1MAX2NV's Avatar
The reason I'm asking is because I want to run my direct port nitrous with SC. I will need the FMU to have adjustable base fuel pressure so I can run my AEM FPR after it for my nitrous system. Prior to the FMU, the fuel pressure will be raising with boost. After the FMU, the fuel pressure will raise like it would on a NA engine. Am I thinking correctly??
Old Aug 27, 2004 | 07:50 AM
I believe that is what Hal does.
Old Aug 27, 2004 | 09:43 AM
Chunger's Avatar
I don't believe that would work theoretically... The fuel pressure after the FMU (or after the FPR if no FMU is present) will be very low so I don't THINK that even an additional adjustable FPR could bump it back to a high enough fuel pressure (34psi)... I COULD VERY MUCH BE WRONG if Hal has already proven it possible, though. I'm thinking the "self adjusting fuel pressures to either side of an "adjustable" regulator will be screw each other up. I'm no flow engineer... always so so with my physics...LOL
Old Aug 27, 2004 | 09:56 AM
Bags's Avatar
****.. I thought the SFMU could not and the cartech COULD.
stephenbags
THANK YOU my BAD
Old Aug 27, 2004 | 11:12 AM
1MAX2NV's Avatar
Hmm...you got me thinking. I think worst case senario would be using an Aux fuel pump bypassing the fuel rails and goes directly to second FPR.
maxima-junky
Nov 10, 2015 09:12 AM
14GmMax
Sep 19, 2015 11:32 PM
Stagnet04
Sep 14, 2015 11:28 PM
