which gauge should I get?
Old Aug 29, 2004 | 05:13 PM
michaelnyden's Avatar
which gauge should I get? and what would be the pros and cons of each...
an EGT or AFR gauge with a wideband O2?
I know the EGT would be the cheaper route...but does the EGT respond fast enough where you can prevent damage to your engine if you were to go really lean for some reason? or is the EGT a slow guage which doesn't respond too quickly to AFR changes...which effectively change the exhaust temps...
Old Aug 29, 2004 | 06:20 PM
matty's Avatar
AFR Gauges ive heard are pointless...get a good EGT gauge, Fuel pressure, and boost and youll be set. The EGT will react fast enough
-matt
Old Aug 29, 2004 | 08:11 PM
also, is there any gauges out there that look like our stock se speedo and tach gauges...ie. white background and black numbers and black needle....
are there any gauges out there that reverse like the stock SE gauges do? ie. white face, black numbers....and turn your lights on to black face, white numbers at night (electroluminescent)?
Old Aug 30, 2004 | 05:11 AM
MaXtUneD's Avatar
autometer phantom gauges...white face with a black bezel...
Old Aug 30, 2004 | 05:46 AM
Stephen Max's Avatar
-matt
The afr gauges that connect to your narrowband O2 sensor are indeed worthless, but michael is talking about an afr gauge or readout using a wideband O2 sensor.
The wideband O2 sensor makes more sense if you're willing to spend the money. Not only is it a direct measuring device (unlike the egt, which only infers what your afr is), but if you get the Innovate LM-1 you get datalogging capabilities for five other parameters as well as afr. I datalog afr, manifold pressure, maf voltage, fuel pressure and throttle position against rpm.
Since I installed my wideband, I don't even look at the egt gauge anymore. I honestly can't tell you what my egt is at the end of a quarter mile, but I know exactly what my afr is at any rpm.
Old Aug 30, 2004 | 07:25 AM
matty's Avatar
How much $$ are you looking at when your all done with that ?? You need a labtop as well ?
-matt
Old Aug 30, 2004 | 07:38 AM
well....the phantom series gauges from autometer look good, but had a red needle...and I have a 95 SE....so I would prefer gauges with white face, black lettering, and black needle
alternatively...I would be willing to put in gauges that are black face, white lettering, and white needle
but it doesn't look like such gauges exist...I have looked around everywhere!!!
I don't know yet how much I want to spend, what is the cheapest wideband solution with no datalogging...just the plain gauge and sensor?
Old Aug 30, 2004 | 08:01 AM
-matt
About $340 for the sensor and controller, another $100 for the additional input box if you want to be datalogging stuff, $60 or so for the analog afr gauge.
Old Aug 30, 2004 | 09:40 AM
Bags's Avatar
VG Ridah's Biatch Hoe
These gauges suck IMHO. Stay away from autometer
Old Aug 30, 2004 | 01:30 PM
so what gauges would you suggest??? if the autometer suck....
....bags, why do you say they suck? from personal experiences? what is wrong with them? low quality?
Old Aug 30, 2004 | 02:02 PM
mtcookson's Avatar
autometer guages are cheap (not inexpensive). that's why a lot of people always get different readins with their boost gauges compared to the higher quality gauges like defi, greddy, etc.
wideband 02 is the only way to go. it gives you the best possible readout as it gives you the exact air fuel ratio. you can get a setup for right over 300 dollars from plx devices. for 509 after shipping you can get the datalogging version of the plx devices wb02 setup. www.plxdevices.com
Miket2006
Mar 1, 2021 03:55 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
