I used the SAFC and got some airflow readings. I think they are to LOW. I want to know if you have a LB/CFM or SAFC airflow% reading for 2/3/4 Gears. Any or all.
I think bags is talking about the % airflow. they are two different calculations because of the different circumference.
then the airflow would read "lower" because of the z32's larger size
Quote:
86% injector duty cycle with 516cc
Originally Posted by MardiGrasMax
I see 4.6v at 14psi86% injector duty cycle with 516cc
Yeah, I don't see a voltage, I see 2 different airflow readings.
And Slimer, I saw 2 different readings with the Z32 Maf. That's why I ask
i read your other thread. good info.
I just think that it might be reading lower because of the size of the maf.
does anyone have the measurements?
Originally Posted by slimer
i read your other thread. good info.I just think that it might be reading lower because of the size of the maf.
Yeah, but with the Z maf, last week @ 8 psi I swore I saw 70% airflow on the SAFC.
And then now @10 psi, I see 50%.
I may have been outta my mind trying to watch the road and watch the SAFC.
That's why I am curious what readings others have seen. And I have a ODBII scanner that shows LB/hr. SO of you have that, That will help as well.
The Z32 maf housing is the same internal diameter as the A32 maf housing.
I have seen as high as 4.39V (datalogger), 67% airflow (SAFC). That was boosting at about 12 psi.
50% seems a tad low for 10 psi.
Originally Posted by Stephen Max
The Z32 maf housing is the same internal diameter as the A32 maf housing.I have seen as high as 4.39V (datalogger), 67% airflow (SAFC). That was boosting at about 12 psi.
Thanks for the info.
Yeah I think so as well. I may have fouled out a plug. I am checking them and compression tomorrow. If I fouled a plug I have to go back to the dyno to check a/f.. darn it
ok.. i feel better now.. I am seeing 4.1xxV @ 10 psi
is that after checking the plug or was it a fluke?
The 70% I think was a fluke, I think I was dreaming or something. This came from a 2nd gear pull today through the SAFC.
