How to wire up a shift light?
Hey guys, I figured I would get the best responses by posting in this forum. I have a shift light lying around that I want to install, but I don't have instructions from the manufacturer. It's got 3 wires coming off the back- black, red and green. I was told by the seller of it that the green wire goes to the back of the tach, but I'm not sure which screw to tap into. Of the 3 screws on the back of the tach, I assume I would use the one which carries the signal, not ground or power. However, I don't know which screw is the one with the signal. Do you guys have any idea?
BTW- This is to help me stay safe when spraying.
I think the best location for it is the top left corner of the steering column. Do you guys know of a place that is sort of out of the way?
He probably set it that low for deminstration purposes only. just like I set my MEVI really low to test that its opening so i dont have to rev the cr*p out of the car to get test it out
-matt
-matt
CorollaULEV
30
Aug 9, 2021 08:11 PM
Viralkill
Aug 17, 2015 10:54 AM
doobadoo
Aug 15, 2015 06:43 PM
