just got sc need help
Old Oct 4, 2004 | 04:38 PM
Max97Stick
i just bought a sc kit it has the 2.87 pulley
im not sure if i should run this pulley but if i do what should i do before installating it
i should get a safc2
fpr
370cc injectors
walbro 255 pump
this is what sc kit i bought
http://www.cardomain.com/id/ymeofcr
Old Oct 4, 2004 | 07:26 PM
Stephen Max's Avatar
If this is your first experience boosting a car, you probably should start out with the 3.25" or larger pulley. A 2.87 incher will produce enough boost to get you into serious engine trouble if you are not very careful. You have to be careful with any amount of boost, but once you get above 10 psi the potential for engine damage from detonation is substantially greater, and you have to go with a JWT tuned ecu, or a J&S Safeguard, or water/methanol injection, not to mention larger injectors to keep fuel pressure down to safe levels.
Start out with a 3.33" or 3.25" pulley, and the basic Stillen kit will give you good results with a minimum of additional expense and trouble. Once you become knowledgeable about what is going on, then go ahead and spend the extra money on larger injectors and other stuff.
Old Oct 4, 2004 | 09:53 PM
meccanoble's Avatar
Sports Button FTW
as long as u stay at 3.125 or higher size pulley u dont need to upgrade your injectors. You already have an 8:1 fmu and get an upgraded fuel pump. You should be fine wit this setup, just make sure u get an SAFC I or II so u can tune. Although u run rich in the lower rpm's, at high rpm u will run lean especially if u have a mevi. I remember putting my SAFC up 20 points as an estimate at 6k rpm.
@ 2.87, you'll need a lot of upgrades which i dont know if u ready for, i would do what stephen says and work wit the 3.125"+ pulleys.
You AIMed me earlier but i didnt save your AIm...
ChristheNite
Also the guys on the board have been AWESOME, namely matty, IANSW and stephenmax. I've learned a TON in the past month and would be willing to answer some questions. Just PM me.
Old Oct 4, 2004 | 10:16 PM
Max97Stick
so im lookin to get the 3.125 pulley walbro 255 fuel pump and a safc2 for beginers where would i look to get these?
Old Oct 5, 2004 | 07:35 AM
ChristheNite
3.125 Pulley - best bet is vortech www.vortechsuperchargers.com - 60 bones.
Walbro 255LPH FP - PM PimpJuice - 89$ shipped w/ tracking number
SAFC2 - Check eBay, they always have some sitting there for around $250.
