dum questions, please dont be a jacka$$
Old Oct 7, 2004 | 06:36 PM
drunkenmunky23's Avatar
wuts a cartech FMU and wut does it do?
wuts a AEM FPR and wut does it do?
i have a 99 S/C max, i want a mevi and i need some type of fuel management system....i can't get an ecu (heard its possible to get a 96 ecu and mess w/ the ecu harness), and i know i can do an safc2 or a emanage but i wanna to see wut else is out there and wut each thing does...thanks
Old Oct 7, 2004 | 07:10 PM
Mad-MAX_SE's Avatar
Still kickin'
they're fuel management units that allow you to adjust the base fuel pressure and the rate the fuel pressure is increased per psi of boost added over the rpm range.
Old Oct 7, 2004 | 07:14 PM
matty's Avatar
A cartech FMU is an Adjustable Rising Rate Fuel Presure Regulator.
http://www.bellengineering.net/Pages...struction.html
An AEM FPR only adjusts fuel pressure at idle, brings it down from 40 to 34 with the Wablro pump. An aftermarket fuel pressure regulator only has a 1:1 rise rise compaired to a 4:1 or a 9:1 on the cartech (whatever it set at)
You already have a s/c so you should have some sort of fuel managment unit of some type...
-matt
Old Oct 7, 2004 | 07:25 PM
yea i dont, thats my problem....i got a HO fuel pump..but no managment....so im looking into, as i said above, an safc2, emanage, cartech FMU, a JWT ecu (which i would prefer, but its a lil hard cuz i have a 99), or anyother type of managment that you guys can suggest thats better then the ones im already considering
Old Oct 12, 2004 | 11:07 AM
SPiG's Avatar
SomePsychoGuy
JWT can reprogram a 95/96 ECU to work with a 99 now I believe. The best way to do it is to get 370cc injectors or maybe 550s depending on wanted power and future mods, etc.
If you do not get new injectors, which is fine for most people, then you will need an FMU such as cartech. You will probably need a new fuel pump too.
Old Oct 12, 2004 | 01:18 PM
densetsu's Avatar
sorry if this is ot, but im curious as to why 99's would be any different ecu wise than 95/96's? i was under the assuption 95-96 maximas were mechanically the same...
Old Oct 13, 2004 | 11:02 AM
SPiG's Avatar
SomePsychoGuy
I assume you meant 95-99 are mechanically the same. For the most part they are very similar, but the ECUs are different.
http://forums.maxima.org/showpost.ph...3&postcount=41
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
