Bad Track night
Old Oct 8, 2004 | 08:22 PM
Redmax's Avatar
Redlinemax Owner
Bad Track night
Well I had another really bad night tonight. My clutch slipped through 2nd and 3rd once the boost really kicked in. Rob at NRH transmissions told me last night it was slipping bad and I had already known that it slipped in 4th But i thought it was still track worthy. My first run I found out that it wasn't 17.5 run at 74 mph I couldn't get the car to move. Second run 15 second flat but in 3rd gear the clutch started slipping at 4k rpm's. So I guess either i got a bad Spec 3 clutch or i didn't break it in properly. Tomorrow Da-max is going to come by so we can punish the car some more to make sure the clutch is toast. The funny thing is normal driving its fine, but once i get on it its done.
I'm running 10lbs of boost and it is holding strong. I think i'm putting down about 320whp
What Clutches do you guys have? I really liked the Spec because of the soft pedal but I don't know whether I want to try another one or go to something different
Old Oct 8, 2004 | 08:34 PM
Nealoc187's Avatar
SLOW
Honestly, I don't know a heck of a lot about clutches, I've never owned an aftermarket one, but I'm going with a clutchnet. If it's good enough to go 11.9 in Matt's car, it's good enough for me. Also I have always heard good things about clutchnet.
Old Oct 8, 2004 | 10:59 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
*evil grin*
Old Oct 8, 2004 | 11:59 PM
iansw's Avatar
http://forums.maxima.org/showthread....ight=Clutchnet
Old Oct 9, 2004 | 05:36 AM
MardiGrasMax's Avatar
ROFL, bad luck again. Get the clutch net.
Old Oct 9, 2004 | 08:13 AM
Redmax's Avatar
Redlinemax Owner
Thanks, good link. I know matts view on his clutchnet clutch. now that you have really broken yours in, how do you like it?
Matt, it never fails......... I'm always by my cars. They all think I'm rich!
Old Oct 9, 2004 | 03:14 PM
Redmax's Avatar
Redlinemax Owner
Ok, well addae came and punished the car today and the clutch is fried. Basically what happens is it holds untill the car makes real power at about 3500 rpm's and then it goes all the way out to 7k and hits the rev limiter. After that it stays in the rev limiter for every gear
Old Oct 9, 2004 | 03:53 PM
MAXIN's Avatar
Which Spec were u running? 4 puck?
Old Oct 9, 2004 | 10:29 PM
Redmax's Avatar
Redlinemax Owner
Spec 3 clutch
Old Oct 10, 2004 | 01:24 AM
iansw's Avatar
Love it - not harsh at all now that it's broken in well.
Old Oct 10, 2004 | 12:02 PM
Pinto's Avatar
normal driving would be fine since there is not much load on the engine. once you get into boost yoru seeing another 100-150ftlbs of torque. there have been many bad stories abotu spec clutches. i had one in my 240 for almost a year (15kmi). i didnt break it in properly and it slipped bad for a while. i took it easy for a couple hundred miles and it got much better, would only slip it i tried to launch at the track. how long was your break in period? this is very crutial to organic clutches. now im using a clutchmasters stage 5 4 puck unpsrung, hold great and is jsut as streetable as my spec. retail on this clutch is only $310 shipped. i got it brand new but second hand for $240
Old Oct 10, 2004 | 03:00 PM
DA-MAX's Avatar
yeah the first time I drove it after we got gas, I punched it hard from a 1st gear roll and it was clean up to the top of 4th no slipping and pulled hard, despite 2nd gear being basically useless on the crappy tires I tried some launches too, but I bogged like a pansy( hydraulic clutches..give me cable anyday ) but then magically we went for another run and blammo slipping like a ****...weird. none the less...the car has some POWAH. its definently gonna be good once this clutch is done! seems a little rich, but holds 10 pounds no prob! finally coming along nicely Corey
Old Oct 10, 2004 | 03:04 PM
Redmax's Avatar
Redlinemax Owner
I had even better luck today, my walbro fuel pump died!
Old Oct 10, 2004 | 03:42 PM
DonSupreme's Avatar
Man I thought I was the only one with all these Maxima problems.
I am N/A and my heavy duty ACT clutch designed to take 460+ lbs of torque is TORE UP (Literally, I couldn't even get the car in or out of gear)!
If I had a camera i would post the pics.
Old Oct 10, 2004 | 08:11 PM
PharoNDmist's Avatar
I really hope that the Spec clutch is not that bad in every case with boost, becuase I just installed the Spec stage 3 also and I'm boosting soon.
Old Oct 10, 2004 | 08:46 PM
densetsu's Avatar
once my setup is done im going to be running on an old nissan key value clutch. yes, im going to use a clutch that is actually weaker than stock... wtf is wrong with me?
Old Oct 11, 2004 | 09:07 AM
LatinMax's Avatar
I thought that you were auto.
Old Oct 11, 2004 | 01:37 PM
Redmax's Avatar
Redlinemax Owner
The pold totaled car is auto. My new car is 5spd. However the auto is sitting in my garage waiting to be sold
Old Oct 11, 2004 | 02:41 PM
LatinMax's Avatar
how much?????
Old Oct 11, 2004 | 06:10 PM
jkklim's Avatar
i use the ACT street clutch
Old Oct 11, 2004 | 08:08 PM
Redmax's Avatar
Redlinemax Owner
Originally Posted by LatinMax
how much?????
4 u 2k.........
Old Oct 12, 2004 | 01:10 PM
DonSupreme's Avatar
My clutch went out too and I ordered the clutch net .... Hopefully it will be here by Thursday!
Redmax, at least your car is driveable. My car is dead in the water.
Old Oct 12, 2004 | 08:34 PM
LatinMax's Avatar
4 u 2k.........
Not for me....but when my car comes out of the shop in the next couple of weeks, with all my new bag of tricks.
I think that some of my freinds will be interested in getting one for them selves. So I will send them your way.
Old Oct 12, 2004 | 09:29 PM
DA-MAX's Avatar
damn man...how'd that happen?
did you call me this afternoon...I saw a DC number on my phone, looked like your work. call me tommorow after noon.
Old Oct 13, 2004 | 08:53 PM
Redmax's Avatar
Redlinemax Owner
My spec clutch is warrantied so it looks like i will try another one. but i believe i will try the one that holds 650lbs of torque. We think it was actually a clutch defect.
Addae, I did call you. Will call again tomorrow. or call me at work
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
