Why does boos tincrease in colder weather?
Just like the title says...
Why does my boost gauge read 1-2 PSI higher when it's below 50 outside?
I am looking for FACTS.
This is one theory...
As a gas decreases in temperature, the viscosity also decreases. Many believe this leads to the compressor (or blower) to be able to "grab" hold of the air better. I believe this follows the argument that adiabatic compressibility is higher for the colder air. This increases the supercharger efficiency and allows for more boost at the same given speed ratio.
your thoughts?
your thoughts?
Originally Posted by slimer
cold air is more dense because the gas particles become closer.
Ok, by the air being denser, your saying you can get more air in the same space? or something else?
your thoughts?
your thoughts?
Originally Posted by seximagtr
actually - it's backwards - viscosity INCREASES as temperature decreases.
Wrong! In the case of a gas (which air is, last I checked), viscosity decreases with decreased temperature. [Source: Unit Operations of Chemical Engineering by McCabe, Smith, Harriott]. However, in the pressure regions we are talking about (1-3 bars), I am guessing viscosity changes are fairly insignificant.
your thoughts?
your thoughts?
Thanks for the FACT
Mizeree_X- never really thought about the drier air, but it makes sense thanks for the input
TKHanson
Nov 24, 2018 01:39 AM
MardiGrasMax
Aug 3, 2007 07:12 AM
jnm2kse
Oct 9, 2000 07:45 PM
