Ordering an SSQV..few ??
Old Oct 25, 2004 | 01:22 PM
matty's Avatar
What flange do I buy ??
Im assuming in need the Universal one http://www.hopupracing.com/hksssblva.html and I found it for $189
The flanges are as follows...
60mm Aluminum
50mm Steel
65mm Steel
I have a coating on my pipes if that matters..
anyone know of any other better BOV ?? ..I have a greddy but i dont think its functioning properly...
-matt
Old Oct 25, 2004 | 06:24 PM
hlh0501's Avatar
Greddy's are prone to leaking. I am very satisfied with my TIAL.
Unless you have aluminum pipes, you'll want the steel flange.
Old Oct 26, 2004 | 03:38 AM
VQ30DES's Avatar
Do you think the tial would be too much for a s/c set-up at 13psi? I think down the road when i get a 3in crossover pipe i might switch to one.
Old Oct 26, 2004 | 04:56 AM
KMax2988's Avatar
Had an SSQV on my Evo for about 100 miles before I scrapped it. Caused compressor surge everytime it opened and HKS strongly recommends that you do not touch the adjustment screw on it due to diphragm possibly ripping (HKS sent out a TSB on it). Now I am using the GReddy Type-S with a home depot spring in place of the 2 springs that it comes with. After boost testing, it holds 25 psi easily without leaking and causes no compressor surge (adjustment screw still in stock position). If you want, I'll get ya the part number for the spring I used and u can try that.
Old Oct 26, 2004 | 06:02 AM
cardana24's Avatar
Blown
I have the SSQV with my V2 set up and I had the 50mm steele flange welded to my charge pipe...so far no complaints
Old Oct 26, 2004 | 06:20 AM
DonSupreme's Avatar
I have the SSQV with my also welded to my v2 setup. It works great, maybe I have compressor surge and don't even know.
When i shift from first to second @ about 2.5k-3K the sound is rather deep and strange so all this talk has me wondering.
If I get on it hard I know its coming out the BOV.
Old Oct 26, 2004 | 06:34 AM
KMax2988's Avatar
You'll hear a distinct fluttering sound from the BOV if it's surging. I heard that surging is a problem with the HKS valve on smaller engines like my Evo, but on bigger engines it works fine.
Old Oct 26, 2004 | 07:38 AM
matty's Avatar
yea whats the part number, maybe ill try that
is it a stiffer spring or weaker ??
-matt
Old Oct 26, 2004 | 08:03 AM
KMax2988's Avatar
it's pretty much in between the small and large spring it comes with, there's a pic of the box in this thread: http://forums.evolutionm.net/showthr...s+intake+stock
http://forums.evolutionm.net/showthread.php?t=88637 <--- HKS response to using adjustment screw for anyone who cares
JakeOfAllTrades
Oct 5, 2015 10:40 AM
220k+ A32
25
Oct 3, 2015 09:09 PM
bigfrank
Oct 1, 2015 12:51 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Pied
Sep 26, 2015 03:29 PM
