how to hollow out FPR for adjustable fpr
Old Oct 27, 2004 | 06:16 AM
MaXtUneD's Avatar
I will be getting a universal adjustable FPR soon, and prior to installing it, how do I hollow out the stock FPR??
Old Oct 27, 2004 | 08:40 AM
Stephen Max's Avatar
With a drill bit that fits inside the inlet and outlet ports. Drill in through the inlet, then through the outlet (or vice-versa). You will create a connecting passageway through the guts of the fpr.
Make sure you get all the chips out before installing.
Old Oct 27, 2004 | 12:39 PM
LatinMax's Avatar
or just by the nipple adaptor.
Old Oct 27, 2004 | 10:48 PM
subs1000w's Avatar
or just buy a 100$ nismo FPR
bolts right up in the stock location
Old Oct 28, 2004 | 08:03 AM
BlackCat's Avatar
RIP '98 Maxima SE
I haven't planned on hollowing out the fpr nor was I planning to buy an adjustable fpr. Is it really necessary to drill out the fpr?
Old Oct 28, 2004 | 08:17 AM
matty's Avatar
Well you can either drill out the stock one and reinstall it or just get a stand off fitting off the fuel rail that will feed your adjustable FPR...Its good to have due because the Walbro raises base fuel pressure
-matt
Old Oct 28, 2004 | 09:03 AM
If you're not getting an adjustable fpr then you need to keep the oem fpr as is. This is just a way of converting the oem fpr into a standoff fitting.
Old Oct 30, 2004 | 04:29 AM
Boosted Maxima's Avatar
Did mine on wed. Take a drill bit (as stated above) and "carefully" drill out the inlet and outlet of the stock FPR *clean it out* THen, Re-install it... run the fuel line from the outlet to your new FPR then back to the tank. Your just using the stock FPR as a fitting to the fuel rail. It will no longer serve as a regulator just a passageway to the new FPR. "See the thread on StockGN Intercooler" if you want to see a pic of my FPR install. I can take more pics if you need. Just e-mail me.
~Scott
Old Oct 30, 2004 | 09:43 AM
sleeper's Avatar
sweet, i presume you have done this. i was thinking about using the nismo fpr, but wasn't sure if it fit our vq. so that is good news, thank you my brother, and if you have a pic, i want to peep it out.
Old Oct 31, 2004 | 12:54 PM
subs1000w's Avatar
yes i have this but its on my VE engine although i bet it will work on your VQ unfortuanitly i dont have a pic yet because i have only had it installed for about 1 week but it does everything i need it to do
Old Nov 1, 2004 | 09:47 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
theres not enough space, i already test fitted one.
Old Nov 1, 2004 | 05:24 PM
sleeper's Avatar
but does it fit the fuel rail ? thanks, hoss.
Old Nov 1, 2004 | 09:17 PM
slimer's Avatar
yeah, it fits perfect in the fuel rail, theres just not that much space beneath the throttle body.
Old Nov 2, 2004 | 05:07 PM
sleeper's Avatar
thanks for the info, your a big help. my man. lol
Old Nov 2, 2004 | 06:10 PM
subs1000w's Avatar
thank god i finaly know i can use a stand off fitting from a VQ on my VE ive been wanting to know this for a long time
Old Nov 3, 2004 | 09:05 AM
slimer's Avatar
there you go!
Its the same on the rb and sr engines too
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
