Looking to add S/C with out changing parts
Oct 22, 2004 | 01:14 PM
some im wondering if its possible to add a S/c with small boost with out me going thru the whole hassle of changing injectors, pumps and all the other things?
Oct 22, 2004 | 02:08 PM
Sure you can. You just install the base sc kit and then not do any changes.
Oct 22, 2004 | 02:46 PM
Assuming the car is bone stock at 190 hp/205 ft.lbs of torque, anyone got an idea of how much it will be after the install of the base SC kit with no other changes at all. I've seen a few numbers but they all seem to have other modifications with them.
Oct 22, 2004 | 03:15 PM
Straight from the stillen website
"Motor Trend Magazine tested one of our supercharged SMX Maximas (December 1998) and got the following results: 0-60 mph in 5.9 seconds (stock was 7.4). Their 1/4 mile time was 14.4 seconds at 98.8 mph vs. stock at 15.5, 90 mph. Their conclusion: "...a roomy...four-door that humbles prestigious sport sedans costing double, trip or quadruple (as much)." The experience of a Maxima equipped with our STILLEN Supercharger is awesome. The car starts and idles normally with just a hint of whine from the supercharger being the only initial clue of what is to come. As the gas pedal is applied, the whine vanishes and car pulls normally to about 3500 rpm. As this is passed, it just flat takes off and pulls hard to red line. Horsepower is increased from the stock 190 to approximately 275 at the flywheel. The 2000 Maxima enjoyed a significantly greater increase. Torque (measured at the wheels) jumps from the stock 176 to 220 ft/lbs."
Here is the link.
Oct 23, 2004 | 10:45 PM
a stock regular sc just the base kit can wear our and break down the engine in time?
Oct 25, 2004 | 06:21 AM
I don't think anyone here has ever posted about their sc'ed engine breaking down from the base sc kit. I've had mine on for 4 years now with no engine problems and my Max is a daily driver.
Oct 25, 2004 | 07:29 AM
Quote: some im wondering if its possible to add a S/c with small boost with out me going thru the whole hassle of changing injectors, pumps and all the other things?
Be sure to either use the auxiliary in-line fuel pump that comes with the Stillen kit, or replace your in-tank pump with a Walbro 255 lph fuel pump. Other than that, you don't need to do anything other than install the kit.
Oct 28, 2004 | 06:36 PM
Is 9psi stock?
Oct 29, 2004 | 03:36 AM
no, like 6psi is stock. He could probaly run 8psi and still really not have to worry about changing anything. This is how everyone starts, thinking the base kit will do...then you get a smaller pulley then more and more stuff...
Oct 29, 2004 | 06:29 AM
What other upgrades are must when upgrading to smaller pulley; let's say a 3.125 pulley?
Oct 29, 2004 | 07:11 AM
Just gt the damn kit and get on with it. I have 96k boosted miles on my max. Running a 3.125/cai/exhuast.... with stock injectors
Hey BlackCat, how many miles did you get your bearings replaced and was that on a v1? Did you have anything else done? I think im do
Oct 29, 2004 | 07:53 AM
Ok, let me just blow $5000 and just get on w/ it
Oct 29, 2004 | 08:41 AM
Quote: Hey BlackCat, how many miles did you get your bearings replaced and was that on a v1? Did you have anything else done? I think im do
I've got the V2. I don't remember the mileage when this happened but it had nothing to do with it. My fault entirely. I simply overtightened the belt because the wet winter weather caused the belt to squeal every time I went on the throttle and that caused the bearings to wear out faster than it should have.
I've already cut off the #6 post to get ready for the 3.125" but I need to get my hands on a pulley puller. My pulley is frozen on the spindle and I couldn't get it off.
Oct 29, 2004 | 04:43 PM
Go craftsman. Real nice one for $21 or so. Damn, how tight is tight. Mine sounds like it has more of a rattle to it. How can you tell ? How much did you say they charged you ? I could always turn my belt 90 degrees and move it a quarter inch. Maybe it is just time, time to be refreshed.
Yes the pulley can get stuck on there. Before I knew any better I tried prying it off with a screw driver. Then I went to sears and got a pulley puller! It makes a big difference
Nov 3, 2004 | 08:13 AM
i wish i could get a S/Cer. Intill then maybe ill get Nitrous, y pipe, and an SP2. I dont think my modding bug will ever stop. ill be 60 driving a pimped out NISSAN flying saucer!
Haha
Nov 3, 2004 | 09:09 AM
Quote: Go craftsman. Real nice one for $21 or so. Damn, how tight is tight. Mine sounds like it has more of a rattle to it. How can you tell ? How much did you say they charged you ? I could always turn my belt 90 degrees and move it a quarter inch. Maybe it is just time, time to be refreshed.
Unfortunately Sears Canada doesn't stock automotive Craftsman stuff other than their ratchet sets and pieces. One place wanted $50 for a puller. The weather is getting pretty cold now and I'm not about to spend 4 hrs in an unheated garage. I took my Dremel in for servicing last night. I think I burnt it out after cutting off that post.
Nov 3, 2004 | 10:00 AM
Quote: Unfortunately Sears Canada doesn't stock automotive Craftsman stuff other than their ratchet sets and pieces. One place wanted $50 for a puller. The weather is getting pretty cold now and I'm not about to spend 4 hrs in an unheated garage. I took my Dremel in for servicing last night. I think I burnt it out after cutting off that post.
In that cold weather what kinda oil you use with your blower ??
Im in NJ where the temps get to about 0-10 on the coldest mornings...last Winter i went to 5W-30 Mobile 1 Sythetic from 10W-30 Mobil 1 that I used for the summer..I have a feeling im gonna stay with 10W-30 now for the winter..
-matt
Nov 3, 2004 | 10:17 AM
Quote: In that cold weather what kinda oil you use with your blower ??
-matt
