516/555cc Injectors for sale
Old Oct 31, 2004 | 05:25 AM
MardiGrasMax's Avatar
http://forums.maxima.org/showthread....34#post3342534
Old Oct 31, 2004 | 07:16 AM
PharoNDmist's Avatar
Do these injectors idle rough, and can they be managed by the SAFC-II or only emanage?
Old Nov 1, 2004 | 06:33 AM
No they idle fine with e-manage, e-manage works like a champ
Old Nov 1, 2004 | 07:45 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Mardi,
Did you try these withOUT the JWT ECU though? If not, please try using the stock ECU with eManage to see how they idle.
Old Nov 1, 2004 | 09:18 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
eManage will idle fine with that size injector, I run similar set up on my SR and it idles fine. I don't see how VQ would idle diff.
Old Nov 1, 2004 | 09:27 AM
IceY2K1's Avatar
There could be many different factors between the two ECUs or even MAF abilities.
Until someone personally verifies it, I'm not saying yay or nay.
Old Nov 1, 2004 | 02:03 PM
Originally Posted by IceY2K1
Mardi,
Sorry, I am not swaping injectors again.
Old Nov 1, 2004 | 02:09 PM
IceY2K1's Avatar
Doh~! Forgot about that, what about your 740s?
If the eManage alone can idle those bad boys, 550s aint ****.
Old Nov 1, 2004 | 09:35 PM
Royal_T's Avatar
Mardi,
have a quick question. you have the JWT ECU set to 555cc, and you used the emanage to programe 555cc to 740cc right. well my question is would the emanage be able to programe are stock injectors to 740cc?
Old Nov 2, 2004 | 08:52 AM
IceY2K1's Avatar
That's what I'm asking him to try....nobody knows yet, since nobody has attempted it with the stock ECU and eManage ONLY.
Old Nov 2, 2004 | 10:24 AM
I'll try it this weekend.
I was considering a shoot out between the JWT ECU and Stock ECU with e-manage. An hour of dyno time should be all it would take and since my friend helped me its not going to be oo much more to do this other than time to get the stock.emanage ecu set up dialed in. I do have the z32 maf, and will not change that.
Old Nov 2, 2004 | 10:35 AM
Royal_T's Avatar
Mardi,
that sounds great, can't wait to see how you do on the dyno, and if are stock ECU with e-manage could support 740cc. Thanks
Old Nov 3, 2004 | 03:57 PM
SX7R has 555s with s stock ECU and e-manage and they idle fine, IIRC.
Old Nov 3, 2004 | 07:03 PM
I put the stock ECU back in and set the e-manage to 7-0-3 for the stock MAF. I set the injectors to 240cc/740cc. And the MAF correction to NSHW02, for the Z32 maf. It started, but idled and reved like poop. I tried a few different combos and this idled and reved best, the e-manage back to 7-0-1 for stock Z32maf and set the injectors for 370cc/740cc. It idled fine, reved fine, and was hunting for 14.7afr. I did not drive it, but im sure tuning would be in order to get it to run right. Its wierd that the MAF change setting didnt work as well with the main unit set for a stock VQ30maf. Perhaps the Z32maf relation to the 370cc injectors it a work around. I would guess that the stock MAF and 740s would be a bit too much for the e-manage correction factor to work with.
Old Nov 3, 2004 | 09:32 PM
Redmax's Avatar
Redlinemax Owner
But does he have the stock maf? or does he have a z32?
Old Nov 3, 2004 | 10:33 PM
Royal_T's Avatar
Mardi,
so you are saying that the 740cc could work with stock ECU and Z32 Maf w/e-manage, but needs work to get the afr down. that sound pretty good cause i cant make up my mind if i want the 555cc or the 740cc for my turbo project. I just don't want to hit the max of the 555cc and then have to replace w/740cc. thanks alot for trying this out for use helps alot.
Old Nov 4, 2004 | 06:05 AM
Stock A32 Maf
Old Nov 4, 2004 | 06:07 AM
Originally Posted by Royal_T
Mardi,
Yes it should wwork, just be conservative while tuning for boost to be sure its good. Just dont dial in 10psi and let her rip, that sort of thing.
Old Nov 4, 2004 | 08:26 AM
IceY2K1's Avatar
You kept the Z32 MAF in for all these tests, correct?
Old Nov 4, 2004 | 08:27 AM
IceY2K1's Avatar
Right, I forgot about him.
Old Nov 4, 2004 | 11:11 AM
Royal_T's Avatar
Thanks Mardi, i think i'll go with 740cc then. also has any one tried a Q45 MAF?
Old Nov 4, 2004 | 01:05 PM
Yes, Z32 maf for all
Old Nov 4, 2004 | 01:06 PM
These will go on e-bay this weekend if no one bites.
Old Nov 10, 2004 | 10:55 PM
sx7r's Avatar
FYI, it idles fine with both A32 and Z32 MAF. i'm currently using the latter.
Old Nov 11, 2004 | 09:25 AM
IceY2K1's Avatar
Thanks...now if I can just remember all this.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Maximan190
Dec 16, 2015 06:01 AM
maxima-junky
Oct 7, 2015 06:13 PM
