MAF location question
Old Nov 1, 2004 | 01:39 PM
|Bijan|'s Avatar
UCF Lexus
Example: The PFI kit --- the MAF is located where the red arrow starts, by the drivers side firewall. If it was relocated to where the arrow ends....would that be possible to work or would there be too much for it to handle?
I know it'll depend on how much boost your running - but is it a bad idea?
Old Nov 1, 2004 | 01:40 PM
Jeff92se's Avatar
I'm needing a caw
Please explain your reasons in technical terms
Old Nov 1, 2004 | 01:41 PM
|Bijan|'s Avatar
UCF Lexus
Basically, will the car function the SAME if the MAF is located in those 2 different locations?
Old Nov 1, 2004 | 01:42 PM
Jeff92se's Avatar
I'm needing a caw
There are numerous threads about this already. Exactly WHY would you want to change it? If you only want it to "run the same" (nice tech reason btw), why change it??
Old Nov 1, 2004 | 01:44 PM
|Bijan|'s Avatar
UCF Lexus
Depending on WHERE a turbo is be located, will determine where the MAF has to be
*hint*
Old Nov 1, 2004 | 01:46 PM
Jeff92se's Avatar
I'm needing a caw
Exactly why would you want to change it from where it is from the pic?? Tech reasons.
Old Nov 1, 2004 | 01:51 PM
Jeff92se's Avatar
I'm needing a caw
You don't have to PM me for an explaination. I already know what it means to run the MAF in each location. Have no idea why you would want to. Or why you feel the need to change everything around. But then again, it's a big secret right?
Old Nov 1, 2004 | 01:52 PM
|Bijan|'s Avatar
UCF Lexus
Well, where would it go with what I showed you? (the MAF)
not a secret, but remember where I used to work?
Old Nov 1, 2004 | 02:09 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
an exhaust shop?? okay....
Old Nov 1, 2004 | 03:20 PM
|Bijan|'s Avatar
UCF Lexus
yea..an exhaust shop
Old Nov 1, 2004 | 04:14 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Bijan.. what are you trying to do???
and if you look at my or jay's setup your answers are right in front of you
Old Nov 1, 2004 | 05:32 PM
vortechpower's Avatar
So I guess that is a yes it would work. I have seen alot of maf there kinda like the v1 kit for the 4th gen.
Then you could put the bov over by the chain drive case...
Old Nov 1, 2004 | 05:57 PM
Bags's Avatar
Also.. see Jeff's turbo
Old Nov 1, 2004 | 06:50 PM
where can you see jeffs turbo?
Old Nov 1, 2004 | 06:58 PM
Bags's Avatar
Old Nov 1, 2004 | 07:27 PM
wow, what are all the vaccum lines going into? I have not had the chance to see a turbo max in person yet. I know I most def need to go for a ride in one!
some kind of booster or something?
Old Nov 1, 2004 | 09:20 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
yeah is that a vacuum booster?
Old Nov 1, 2004 | 09:24 PM
Jeff92se's Avatar
I'm needing a caw
It's just a big vacuum source.One line from the intake manifold. Then all the things that need a vacuum/boost signal are routed there
Old Nov 2, 2004 | 06:11 AM
Shadow's Avatar
It's just a vacuum block/source. I got sick of all the stupid little plastic tees I was running before with the SC. This block is tapped off of the brake booster line. I actually picked up about 4psig of vacuum. When you run too many plastic tees, there is too much chance of leaking. Wastegate, BOV, FMU, boost gauge, FPR are all run off of that. 1 is just blocked off.
Old Nov 2, 2004 | 10:45 AM
Royal_T's Avatar
Shadow,
where can i get a vacuum block at? Thanks
Old Nov 3, 2004 | 05:36 AM
DA-MAX's Avatar
Originally Posted by Royal_T
Shadow,
get the parts from McMastercar.com...I was running the same thing on my Integra(off the BB hose), makes life so much easier...
6 outlet mani # is: 5469 K151
plugs part# is: 50785 K21
inlet/outlet barbs # are: 44555 K131
total is like $26...the GE and other "name brand" vac boxes are more pricier for the same function.
nowadays when I do a car, I couldn't see ANY other way to run vac llines.
Old Nov 3, 2004 | 09:11 AM
slimer's Avatar
where do you mount it at and are the barbs small enough for the vac lines?
Old Nov 3, 2004 | 11:46 AM
Redmax's Avatar
Redlinemax Owner
So why you aint show me where to get one before? You know i can't stand them damn T's
Old Nov 3, 2004 | 12:46 PM
1MAX2NV's Avatar
Looks like the barbs are for 1/4" ID hose so it should fit 5/16" hose fine.
Old Nov 3, 2004 | 12:52 PM
1MAX2NV's Avatar
According to the website, the inlets are 1/4" pipe thread (NPT) for that manifold so wouldn't you need two 1/4" NPT for the inlets (44555 K132). Then, six 1/8" NPT or six 1/8" NPT plugs for the outlets?
Old Nov 3, 2004 | 01:16 PM
1MAX2NV's Avatar
Cool site. I found some metric compression fittings on there.
Old Nov 3, 2004 | 01:17 PM
DA-MAX's Avatar
corey: you should have bought mine after I sold it buy one from that place and we'll put it together
slimer: you can mount it anywhere...it has screw holes. I'm ghetto, I use zip ties since yalls BB line is on the firwall, drill it into there
tony: I bought 3 plugs and 6 barbed fittings since I knew I'd at least have 3 vac accessories(BOV, gauge, EBC) off the break and never less than that.
Old Nov 3, 2004 | 01:34 PM
1MAX2NV's Avatar
actually, I was asking the inlets are not 1/8" NPT but 1/4" NPT right?
Johnny9595
Sep 3, 2015 05:18 AM
95Maxi
Sep 2, 2015 08:49 PM
95Maxi
35
Sep 2, 2015 10:37 AM
95Maxi
Aug 29, 2015 09:38 PM
