help if u can
Old Nov 8, 2004 | 11:17 AM
maximaintheface's Avatar
help if u can
ok my dads gtp is running liek crap it stutters really bad the supercharger wont go past 7 on the gauge and its goes to 10. i replaced the belt plug wires plugs and oil. do u think it has a vacum leak or a bad gasket somwhere i know its not a max but i want to help my dad out. if anyone has any ideas id like to hear them. thanks
Old Nov 8, 2004 | 11:20 AM
also btw the oil pressure is almost constanly 120 it used to stay way lower and now its at 100 when u are idle and goes way up when you give it any kind of gas.
Old Nov 8, 2004 | 11:35 AM
Drjmaxx88's Avatar
any oil leaks?
runs like crap huh.
Is it making any noise from the supercharger pulley. We have a car at school thats doing this too.
Old Nov 8, 2004 | 12:25 PM
Redmax's Avatar
Redlinemax Owner
email redmaxpa007 he now has a gtp, he maybe able to help you out
Old Nov 8, 2004 | 12:28 PM
no it doesnt make any noise form the charger it just wont fully boost and the oil pressure is crazy and it just stuters really bad. the pully is ok im pretty sure. it doesnt make any noise at all.
Old Nov 8, 2004 | 12:29 PM
and i dont think there area any oil leaks but the oil gets dirty really really fast
Old Nov 8, 2004 | 05:21 PM
any one have any idea why the oil pressure would be so high?
Old Nov 9, 2004 | 05:58 AM
Stephen Max's Avatar
Gunk or little bits of engine in the oil galleries?
Old Nov 9, 2004 | 10:41 AM
the oil is just like blackish after about a 1000 miles im gunna flush it out. i changed the plugs wires and cleaned the distributer conections and thats about all i could do cuase its not like it has a cap and roater its a wierd looking thing
Old Nov 9, 2004 | 12:19 PM
densetsu's Avatar
try having the motor flushed. if the oil is getting that dirty in only 1000 miles then you may very well have some buildup in the motor - that would also be a reason your oil pressure is higher than normal.
Old Nov 9, 2004 | 12:20 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
seafoam that bish.
Old Nov 9, 2004 | 12:31 PM
where do u get seafoam?
Old Nov 9, 2004 | 01:15 PM
slimer's Avatar
you can get it at napa
Old Nov 9, 2004 | 01:30 PM
dope thanks, what should i use oil wise to flush it out they have that stuff u put in ur oil and you turn the car on do you think that will flush eveything out?
Old Nov 9, 2004 | 01:46 PM
densetsu's Avatar
have it flushed out professionally for the best results. they use a pressure system to make sure all debris is removed internally. if not, you can try some of the numerous self-flush products they have at any autoparts store. the only one ive used is valvoline's and it is pretty good. in my opinion though, the best bet would be to have it done professionally...
Old Nov 9, 2004 | 03:09 PM
Drjmaxx88's Avatar
If your oil gets dirty really fast the could be because air thats not being filtered is getting burned. Is there an intake leak?
Old Nov 9, 2004 | 05:08 PM
not that i could see or hear mabye tehre is but lookd an it seemed to be just fine. im not sure mabye ther is one somwhere and i just didnt see it
Old Nov 11, 2004 | 09:08 AM
what about the boost it doesnt go up all the way after i take care of everything else should it go back up or is somthing wrong with that
