v2 fit on v1 bracket /4th gen?
The thing that makes me think it will fit is i think iansw actually has or atleast had a V2 blower on a V1 bracket. I'm pretty sure he did. I know someone did so its definitely doable, just not sure if extra work was involved.
Well, I won a bid on ebay for a v2 blower. The description says E-trim? I wonder if that is just an error because there is no E-trim on vortech's site. Aynone have a reasuring answer ....
It is suposed to be barely used, I hope.
It is suposed to be barely used, I hope.Impeller speed of 65,000 rpm. 1200 cfm, 825 hp, 76% efficiency.
Looks like a good find!
It is suposed to be barely used, I hope.Wrong rotation!
Are you saying its the wrong rotation because of the picture shown because vortech offers the E -trim in clockwise and counter clockwise. This is what happens when you let the wife go christmas shopping without you !! I really hope this is in my favor. No more over spin for me
not that I ever had any yet..
What does STD/HD mean.
not that I ever had any yet..What does STD/HD mean.
I under stand. I was just checking out your max Stephen, damn. Do you think the front pipe was benefical? Did you lose any pep or response? Would you guys go for the v2 sq-sc trim or if this e-trim is ccw go ahead and do that? Stephen you said you got the headers and made almost 350whp, what size pulley are you runnig?
I like the rpm capacity of the e-trim. It would go great with a raised rev limit and small pulley without worrying about over-revving the blower.
I'm running an ASP 3" pulley. 12 psi at 7200 rpm, V1 blower.
Originally Posted by Stephen Max
I think the front pipe helped. It resulted in a 30 deg drop in intake temp (I have an intake air temp gauge, so I'm not guessing about that), with only about .2 psi drop in boost pressure. Lowering intake temps 30 deg is good for 3% increase in power. That comes out to 10 hp.
A phone number too would be cool
-matt
Originally Posted by matty
By chance, Stephan, do you know the part Number for that ASP Pulley and are they orderable (in stock in other words)
-matt
-matt
Here's their email addy: asp@aspracing.com
MAXSE5SPD
Sep 17, 2022 04:00 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
