vortech superchargers
Old Nov 30, 2004 | 11:45 AM
Max97Stick
does anybody know what i have to do ot make the 3.125 fit on my v2 that i just bought from vortech suoerchargers
Old Nov 30, 2004 | 11:56 AM
vortechpower's Avatar
It fits just like the one thats on there now. I would use some medium strength thread locker on the screw holding the pulley on. You will need a different size belt as well, I dont know what size that is.
Old Nov 30, 2004 | 12:07 PM
cardana24's Avatar
Blown
belt size is in the stickies
Old Nov 30, 2004 | 12:13 PM
Stephen Max's Avatar
If the pulley is too tight to slip over the shaft, heat it up with a heat gun.
Old Nov 30, 2004 | 12:20 PM
BlackCat's Avatar
RIP '98 Maxima SE
Don't forget to cut off the post directly below the circular opening for the pulley.
Old Nov 30, 2004 | 02:35 PM
give it a good smack with the hammer covering the top of the pulley with a piece of cardboard
Old Nov 30, 2004 | 02:38 PM
Max97Stick
anybody in ny can help me out with this
Old Nov 30, 2004 | 02:39 PM
Max97Stick
help
i have to cut it to get the 3.125 pulley on?
ok so if i order the 6 rib 3.125 from vortech it should fit nothing is needed like a spacer or anything
Old Nov 30, 2004 | 03:19 PM
BlackCat's Avatar
RIP '98 Maxima SE
Yes. The consensus here is that you have to make clearance for the belt. The post had to be filed down for a 3.33" so you can imagine what would happen with a 3.125".
Yep, I swapped out my 3.33" for a 3.125" a couple of weeks ago. I had to buy a cheap $14.00 pulley puller because my 3.33" was stuck on the spindle.
Old Nov 30, 2004 | 03:30 PM
Max97Stick
oh ok i guess ill just put another belt on for know
after the winter ill upgrade
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
