Compression results
Old Dec 11, 2004 | 10:20 PM
iansw's Avatar
Compression results
Compresion test results:
Cyl # - Results
1 - 180
2 - 180
3 - 180
4 - 178
5 - 182
6 - 170
All in all, I'm happy with it.
I've been running SC'ed and "driving it like I stole it" for 1.5 years now....about 25k miles.
Old Dec 11, 2004 | 10:26 PM
Bags's Avatar
VG Ridah's Biatch Hoe
good info and congrats on having a solid motor
Old Dec 11, 2004 | 10:30 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
you boys are up late. congrats to the solid motor.
Old Dec 12, 2004 | 12:10 PM
iansw's Avatar
We also did a compression test on maximase86's 86 Maxima Engine with 210k on it.
195 across each and every cylinder!!!
I was like:
Old Dec 12, 2004 | 12:27 PM
slimer's Avatar
now thats impressive!
Old Dec 12, 2004 | 02:34 PM
I30tMikeD's Avatar
Good to hear, makes me feel more confident on my turbo future.
Old Dec 12, 2004 | 03:36 PM
iansw's Avatar
I put new plugs in today (BKR6E-11 - 1 step colder)
Gapped to .035.
Anyway - while I was in there I did another test just for the heck of it.
Keep in mind this is a different gauge.
1 - 180
2 - 180
3 - 180
4 - 174
5 - 184
6 - 170
The difference in 5&6 has me a little worried. I'll have to keep my eye on that. It's right on the line of what's "spec" according to the FSM.
Old Dec 12, 2004 | 03:45 PM
SR20DEN's Avatar
VQ Wizard
This is what I got from Matts 6k mile VQ30 last week.
1. 204
2. 197
3. 198
4. 188
5. 195
6. 190
And from the 65k VQ30 that we had to remove
1. 151
2. 168
3. 176
4. 176
5. 6
6. 50
I did a compression test on a VQ35 a couple of weeks ago and got 216-204 across the board.
I hope you guys are pulling the ECU and fuel pump fuses before you spin your engine. It's very bad for the ECU to attempt to fire a coil that isn't there. You can easily fry a BMW DME by doing that.
Old Dec 12, 2004 | 06:05 PM
matty's Avatar
Whats the proper way to do a compression test ?? Do you guys take out all the Plugs and go cyl to cyl and do it that way...or do it cyl by cyl taking out and replacing the pluf as you go along ??
-matt
Old Dec 12, 2004 | 06:35 PM
I30tMikeD's Avatar
-matt
I believe you take one out at a time.
Old Dec 12, 2004 | 07:16 PM
SR20DEN's Avatar
VQ Wizard
I usually remove all of the plugs at once and go down each bank. I keep the starter spinning with the TB wide open untill the digital meter stops climbing.
Old Dec 12, 2004 | 07:23 PM
subs1000w's Avatar
most pull all the plugs and spin the engine for 4 or 5 seconds
Old Dec 12, 2004 | 08:00 PM
iansw's Avatar
According to the FSM, you pull all plugs then crank 5-7 times.
Interesting you ask however - because test #1 was pulling 1 plug at a time with all the coil packs disconnected, and #2 was with all plugs pulled.
As you can see, it doesn't make much difference.
Old Dec 12, 2004 | 09:57 PM
Bags's Avatar
And it also calls out the fuel pump fuse being removed and the TB being held open.
I'd do it the same way every time, that way the results are not skewed.
Old Dec 12, 2004 | 10:09 PM
iansw's Avatar
Yes - I did both of those things both times of course.
If you don't open the throttle you get readings 30-40 below what they really are.
If you don't pull the fuse, either your car tries to start (if you have any plugs and coil packs plugged in) or you spew fuel out of your open cylinders.
Yesterday I hadn't read the FSM - today I had.
Of course, my tank fuel pump is blown anyway (2nd Walbro in 2 months ).
Running fine off the T-Rex Aux pump.
Need to re-re-replace the Walbro ASAP however.
Old Dec 12, 2004 | 10:17 PM
matty's Avatar
Where you buyin your walbro's from ??
I think mine is shot because at idle when put boost pressure (10psi with Midyvac) on the Cartech I dont get any fuel pressure past 55...witch it very strange to me..I cant understand...When I drive the car, it goes up to 80-90psi at full boost, so at full boost its fine.... ??? Dont know ???
-matt
Old Dec 12, 2004 | 10:19 PM
iansw's Avatar
Don't know where your problem lies....
But I bought both walbros brand new.
The 1st one may not be actually bad - I have to do some tests with it. I think maybe it was just installed at the wrong angle and wasn't catching the last 1/8th of a tank.
The 2nd one was from playing with the FMU on the Dyno and pushing my Fuel up to 120PSI on accident. (can you say 7:1 A/F and flames out of your exhaust?) Ran fine on the Dyno, but as soon as I left the shop it was doing 30PSI at idle and wouldn't go over 40 under boost. Car misfired and stuttered.
Thank god i left the T-Rex in and just had to pull over and hook it up.
Old Dec 13, 2004 | 04:56 AM
SR20DEN's Avatar
VQ Wizard
There are some old threads about Walbro issues. You can't just slap those things in without trimming the two small barbs on the outlet side.
Old Dec 13, 2004 | 06:09 AM
iansw's Avatar
Did you mean to say "can't"?
Old Dec 13, 2004 | 07:53 AM
SR20DEN's Avatar
VQ Wizard
Old Dec 13, 2004 | 08:08 AM
95turbo gxe's Avatar
ive done a few test on the vg30 Thats in my 3rd gen.
Before boost I had 180to 178 on each cylender
Now after running very lean and driving the **** out of it for almost 2 months
now I still have 180to 178 on each cylender.
Old Dec 13, 2004 | 09:01 AM
iansw's Avatar
I had 215 in each cylinder before I started boosting.
Seems the boost has kicked a lot of carbon out of the cylinders.
I also am running very lean up top. However, the new JWT Chip will be here tomorrow and fix that with the Z32 MAF running.
Old Dec 13, 2004 | 12:20 PM
Broaner's Avatar
2060lbs and falling...
On the two cars I've tested I've gotten all 200+ PSI. Is that due to my method or just carbon buildup? One was mine with 135K and the other was VQuick with 85K. Is this alright? Is there any way to get the carbon out? Why is it bad to leave it in there? If you want a bit more power that would increase the CR right? Or does the carbon hold heat and cause pre-detonation?
Old Dec 13, 2004 | 12:47 PM
slimer's Avatar
seafoam or some other detergent that you feed through the vacuum lines
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
Sep 27, 2015 08:37 AM
