E-Manage ??
Old Jan 5, 2005 | 11:45 PM
matty's Avatar
E-Manage ??
I was thinking I may not go with the JWT any more after reading a bit on it ..
I have 370's, Z32 Maf and the JWT ECU ready in my room to go in.
I could sell the JWT easily but I need to know what I will need for E-Manage for injector support and the stuff I will need and how much it will all cost....
Whats J&S ??
Will I need that to run E-manage ??
What will I need to get E-manage running ??
Will I need a Wide band controller right away....
And lastly is e-manage easy to insall...It runs through the stock ECU.
Cut me a break, I dont know much about J&S and E-manage and I wanna learn
This is only a thing Im thinking of so it really isnt decided yet what I am going to do. I bought the JWT because it seemed easy, plug and play but for perfect tuning I think I need E-manage and J&S...
-matt
Old Jan 6, 2005 | 01:25 AM
I30tMikeD's Avatar
If you have the JWT ECU already in hand I would just use that.
For e-manage your gonna need the unit, support tool, injector harness, igntion harness, and a lap top. Along with that you will need a wide band o2 sensor that can data log, something like the Zetronix ZT-2 and an S-AFC to make the fuel corrections. You might be able to make the fuel corrections with e-manage though an additional pressure sensor harness or the injector harness...not sure about that. You may not need the S-AFC. Your looking at about a $1000 for all that right there.
The unit is about $250
support tool about $120
injector harness $40
Ignition harness $40
pressure sensor harness if needed $120
Used lap top if you dont have one $150
ZT-2 wide band o2 bundle $300
J&S safe guard is not necessary at all but will help with tuning because it tells you when/if detonation occurs and can control it via each cylinder. I think J&S is about $600
Old Jan 6, 2005 | 05:31 AM
superdave2
Mike, you can make all the fuel adjustments with emanage. No need for the SAFC.
IMO, if you are going to have a mild "static" set up, just keep what you have. If you think you will change your set up a couple times down the road or you want to play with timing/fuel control yourself, go with the emanage.
JWT=plug n' play
emangae=diy tuning
Old Jan 6, 2005 | 08:41 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Install the JWT...
Old Jan 6, 2005 | 09:08 AM
Royal_T's Avatar
If you are looking for a widband, there is a group deal on my350z.com for the Zetronix ZT-2.
Old Jan 6, 2005 | 12:55 PM
ChristheNite
Matty if you DO go the emange route - I got dibs on your JWT ECU...
knight_yyz
Nov 6, 2015 02:34 PM
knight_yyz
Oct 24, 2015 08:05 AM
