oil drain size
Old Jan 11, 2005 | 05:22 PM
subs1000w's Avatar
oil drain size
help me decide on weather to use AN-10 or AN-12 oil drain hose i notice most seem to use 10 but ive seen 12 on other cars and the cost is minimal
and do you guys suggest using a 45degree fititng at both the turbo and oil pan or did you use a straight fitting at the turbo and 90 at the oil pan
Old Jan 11, 2005 | 05:54 PM
DanNY's Avatar
Ad·min·is·tra·tor
AN10 is close to 1/2...that should be ok...if there's room for AN12 then go for it...it's just gravity flow.
45 and 45 should be better than a straight up 90.
Old Jan 11, 2005 | 06:37 PM
Bags's Avatar
VG Ridah's Biatch Hoe
10an would be what I would use.. I would not want a -12an hole in my oil pan
and 45 deg at the pan and straight at the turbo
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
knight_yyz
Nov 1, 2015 01:34 PM
