Is MAFS Same as O2 Sensor
Old Jan 30, 2005 | 10:06 PM
under5295's Avatar
Hey all,
Heres my Question. Is what nissan calls the Mass Air Flow Sensor the same thing as the "O2 sensor"?
Let Me break my problem down for you all. I have future plans of turbocharging my 2001 Max.
So I am slowly buying parts that I will need (i.e. Greddy e-manage, & an A'PEXi Auto Timer for turbo).
I just got the A'PEXi Turbo Timer and I want to install it, but I am unclear on one part of the instructions.
It says Splice the white wire (O2 sensor signal) form the relay (the timer relay that is) into the O2 sensor wire from the ECU.
All help is greatly appreciated!!! Thanks Devilish
Old Jan 30, 2005 | 10:35 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
maf and o2 are completely different.
Old Jan 30, 2005 | 11:02 PM
hlh0501's Avatar
No. MAF meters flow in the intake tract, O2 meters % oxygen in the exhaust.
Why is your turbo timer referencing O2 anyways?
Old Jan 31, 2005 | 08:09 AM
Stephen Max's Avatar
The Apexi SAFC has a sensor check feature so you can monitor O2 sensor voltage. Maybe the turbo timer does too.
Old Jan 31, 2005 | 02:19 PM
SPiG's Avatar
SomePsychoGuy
The MAF is the Black tube thing with a box on top with 3 wires connected between your trottle body and your air box. An O2 Sensor is a little tube thing connected on your exhaust. You should have at least 3 of those.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
