Help with piping
Old Feb 4, 2005 | 10:12 AM
chris'smax's Avatar
Help with piping
I am ordering some piping today to do a custom 3" high pressure pipe and switching to a cai setup on the inlet side. Before i order it i wanted to know what type piping should be used on the high pressure piping.
Old Feb 4, 2005 | 11:17 AM
|Bijan|'s Avatar
UCF Lexus
alumnized steel
Old Feb 4, 2005 | 11:26 AM
Jeff92se's Avatar
I'm needing a caw
16ga alum pipe is fine. For intake stuff. You can use anything. Steel, alum, ss steel, titanium etc.... If you are welding it yourself, alum steel is the cheapest/easiest to weld cut etc..
Old Feb 4, 2005 | 10:36 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Chris,
Sounds like a good plan. Just make sure you clock the blower like StephenMax used to have to eliminate that hard bend at the blower outlet.
Also, once you successfully complete this, you will benefit from a larger throttle-body. I'm starting to believe StephenMaxs' Pathfinder Throttle body could work on us 5th gens.. You'll need to bore out the intake manifold inlet a bit to match the PF TB diameter again like StephenMax did, but the adapter plate he makes already mates up to our intake manifold, so no fabrication would be necessary.
You'd be my hero, if you could try this.
Old Feb 5, 2005 | 11:06 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
what was was it clocked?
about 15 degrees counter clockwise?
Old Feb 5, 2005 | 10:54 PM
IceY2K1's Avatar
You tell me.........
Old Feb 6, 2005 | 08:05 AM
hlh0501's Avatar
Originally Posted by Soul Fly
alumnized steel
^^ Keep in mind, this will rust. (less you powder coat, etc)
Aluminum would be my choice (although it is significantly harder to weld, and more expensive - yet reasonable)
Old Feb 6, 2005 | 08:07 AM
chris'smax's Avatar
how do you clock the blower?
Mardi Gras+Whiskey+girls flashing their *****=
Old Feb 6, 2005 | 09:26 AM
slimer's Avatar
alex, that looks right.
should have done something with my piping before i got it powdercoated.
ugh.
Old Feb 6, 2005 | 08:36 PM
slimer's Avatar
i have another question about stephen's reclocking the blower.
stillen sells those silicon couplers that replace those parts, does anyone have any idea to what part numbers they would be? i'm going to scour stillen's website now.
wish me luck
steve
Old Feb 6, 2005 | 08:39 PM
slimer's Avatar
found it
http://stillen.com/Sportscars_detail...d=48532&page=1
pretty pricey.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
