VQ35 and boost
Old Feb 10, 2005 | 07:40 AM
Stephen Max's Avatar
VQ35 and boost
I read a while back in my350z.com about problems people were having with boosted VQ35's resulting in thrown rods. The theory at the time was that detonation was to blame, along with maybe a weak rod design.
Anybody have any more up-to-date information?
Old Feb 10, 2005 | 08:03 AM
chris'smax's Avatar
I also read the same thing. Wasn't it around 10-12 psi that people started having problems? Also I thought the 3.5 had a higher compression ratioi than the 3.0.
Old Feb 10, 2005 | 08:16 AM
BigDogJonx's Avatar
Its not the compression since the 3.5vq has a 10.3:1 compression compared to the 10:1 that the 3.0vq has.
Dixit
Old Feb 10, 2005 | 08:47 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Two issues:
1)They lightened the whole assembly and the rods can only handle 450-500whp with EXTREMELY careful tuning/timing. People have bent rods much lower with just okay tuning.
2)Timing. The VQ35s use heavily advanced timing, so if not retarded aggressively, you can get some detonation that will easily bend rods.
There is a THIRD suspect, which is the crank position sensor wire supposedly picking up interference on the way to the ECU and causing a catostrophic failue due to wrong firing time. Anyways, they are selling a shielded cable or something to combat this and rumor had a TSB coming out, but nothing so far.
Anyways, you'll be fine up to 400-450whp with a hell lot more torque StephenMax, so do it~!
Old Feb 10, 2005 | 08:49 AM
IceY2K1's Avatar
Hi Dixit....love that car.
Old Feb 10, 2005 | 09:12 AM
Thanks for the good info, Icey.
The reason I ask is that I may be able to get a VQ35 crank and rods pretty cheaply, which would allow me to do the VQ33 stroker mod. I will have to get aftermarket pistons to drop the CR back down, though, and I'm wondering what CR to settle on. I don't intend to boost any higher than what my 2.87" pulley will produce. I would prefer not any lower than 9.5:1, if the rods can handle it. Sounds like they will, since I am aiming for 400 whp.
I know people are going to say just drop in a VQ35, but I am not ready to do that yet.
Old Feb 10, 2005 | 09:27 AM
Or, conversely, keep the high compression for torque, and reduce boost to some safe level. What level would that be, I wonder?
Old Feb 10, 2005 | 09:31 AM
IceY2K1's Avatar
I would keep the compression and use antidetonation measures like SwainTech coating, alchohol/water injection, INTERCOOLER, and if necessary drop the dynamic compression with some bigger overlap cams.
If you used the DET pistons, you'd probably end up with around the same 10.3:1 compression as a stock VQ35, guessing though.
Old Feb 10, 2005 | 09:39 AM
mtcookson's Avatar
I've read some claims that point to the block design, being an open deck. Some people claim that under high power the open deck design allows the cylinders to kind of shift causing the major damage which why those companies have created the sleaving kits or whatever.
That was my take on everything...
Old Feb 10, 2005 | 09:42 AM
IceY2K1's Avatar
I've read that too, however that is truely false...guys are running 700whp on the block without issues and the damage occuring on stock blocks is detonation or preignition related. The sleeves are for the nutzos wanting 1000+whp.
Old Feb 10, 2005 | 09:50 AM
mtcookson's Avatar
cool... i figured it wasn't the block since we all know nissan's blocks are usually damn strong. i knew there had to be something fishy about that.
Old Feb 10, 2005 | 10:46 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
i heard it was a bad batch of rods.
Old Feb 10, 2005 | 10:52 AM
stephenlc's Avatar
Can't you get 400 whp with the 3.0 Stephen??? Arn't you like at 350 whp or something??? Maybe ported heads and a 3 angle valve job??? You could also take out on of the layers on the head gasket to increase the compression ratio a little.
Or you could go 3.5 with ported 3.0 heads and timing chain cover, and the 3.5 cams. I think you would reach 400 whp real quick with the blower. Also you could switch out the rod bolts with the 2005 track model rod bolts that are suppossed to be stronger. they are only like $2.50 each instead of like $150 set of ARP ones. With an intercooler and water/methanol and probally lower boost you might be fine with the higher compression.
Old Feb 10, 2005 | 11:22 AM
IceY2K1's Avatar
Yes, he can hit 400whp with the VQ30, however he won't have the TORQUE of the VQ35s unless he uses a small N20 shot.
I'd see how far I could push the VQ30 for reasonable costs and then drop $400 or so for a NX kit.
Old Feb 10, 2005 | 11:29 AM
I've got some spare 3.0 heads I'm playing with. They are very good right from the factory, with 3 angle valve jobs and valves that are about as big as you can get in there.
I think I could get to 400 hp with the VQ35 cams I have ready for install and a better flowing exhaust, maybe an electric cutout.
Old Feb 10, 2005 | 11:30 AM
I've thought about nitrous, but I would prefer a combination of built motor for torque with the SC to augment hp.
Old Feb 10, 2005 | 11:34 AM
IceY2K1's Avatar
Gotta add displacement then....
Can't wait and did I tell you you're my HERO?
When I "grow" up, I want to be just like you.
Old Feb 10, 2005 | 11:42 AM
Stop that! You're embarrassing me!
Old Feb 10, 2005 | 11:43 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Or change his hairdryer
Old Feb 10, 2005 | 11:44 AM
I need to qualify this by saying that the VQ35 heads are a big improvement in flow, nevertheless.
Old Feb 10, 2005 | 11:53 AM
IceY2K1's Avatar
Baah...show me where 13whp/psi non-intercooled is inefficient or the VE isn't adequate.
Yes, VQ35 heads are superior and AMAZING(105% VE on 350Z even), however with Mardi, Hal, etc. pushing that much air through stock heads/cams, they ARE NOT the bottle-neck.
Buy Tomei 268 cams and we'll see what these heads can flow: http://www.z1auto.com/prodmore.asp?m...ine&prodid=521
http://www.tomei-p.co.jp/_2003web-ca..._camshaft.html
Old Feb 10, 2005 | 02:11 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
You could always buy the Pauter rods available for the VQ35. They are insanely strong...
Old Feb 10, 2005 | 02:18 PM
IceY2K1's Avatar
Pauter rods are overkill...there are better choices for non-turbos.
Old Feb 10, 2005 | 02:47 PM
MAX2000JP's Avatar
You guys are all wrong It's something really simple.
http://www.airpowersystems.com.au/35...ank_signal.htm
Old Feb 10, 2005 | 02:57 PM
IceY2K1's Avatar
Say again?
....There is a THIRD suspect, which is the crank position sensor wire supposedly picking up interference on the way to the ECU and causing a catostrophic failue due to wrong firing time. Anyways, they are selling a shielded cable or something to combat this and rumor had a TSB coming out, but nothing so far.
Old Feb 10, 2005 | 03:04 PM
MAX2000JP's Avatar
Say again?
Your first two issues are wrong The reason people were blowing their motors was because of timing issues cause by the crank position sensor.
Old Feb 10, 2005 | 03:45 PM
IceY2K1's Avatar
Hahaha....you don't really think that's the cause of them all, do you?
I've seen the damage in the pictures, MOST were detonation caused...not ECU firing at the wrong time.
Old Feb 10, 2005 | 04:03 PM
MAX2000JP's Avatar
I am sure poor tuning, bad gas, etc. could also be the cause. My friend Brian just ordered a APS TT kit and was told by one of the nation's best 350Z tuners that this was the problem. Detonation is what kills an engine and APS's explanation seems to hold true.
"When the signal from the crank angle sensor becomes erratic, so does the ignition timing (in addition to other functions). Ignition timing is a vital tuning parameter particularly in forced induction applications. If the ignition timing becomes retarded from the optimum point, the engine will produce less power and torque. However, and most alarming is when the ignition timing becomes advanced from the optimum point, pre-ignition and detonation may occur. Detonation places extremely high loads upon a variety of engine components such as pistons, conrods, bearings etc and the chance of failure of each or all of those components becomes very high."
Old Feb 10, 2005 | 04:08 PM
JClaw's Avatar
Just buy a VQ30DE, put that bottom end in under your VQ35DE heads and intake manifold. It drops the compression down to 8.9:1 and you have a much better/higher flowing upper end, the more agressive VQ35 cams and the VQ30's boost proven bottom end. You can pick up a used VQ30 for like 400$. It'd be cheaper than buying aftermarket internals.
Doing the opposite (VQ35 bottom/VQ30 upper), as someone suggested, would bring the comp up to 11.5:1. Horrible for boost.
Old Feb 10, 2005 | 04:38 PM
MardiGrasMax's Avatar
My block is ready at the machine shop
Old Feb 10, 2005 | 04:39 PM
MAX2000JP's Avatar
It's easier to do a VQ30DE and VQ35 heads, with a 5th Gen VIAS manifold. You will run into problems with the throttle by wire.
Old Feb 10, 2005 | 11:32 PM
JClaw's Avatar
No. Just do like Tilley. Use the entire 3.5 upper end (heads AND intake manifold) and put a 2001 pathfinder 70mm throttle body. Cable driven, but the same size as all other VQ35DE throttle bodies.
You can also mod the VQ35DE electronically controlled throttle body to be cable driven, that's what Tilley did when he swapped his 3.5 in his girl's '97. Both ways will work fine.
For example, here are his dyno results:
VQ35DE bottom end w/VQ30DE heads & 00-01 VI and super high 11.5:1 compression= 226whp and 205wtq
full VQ35DE (still off his 4th gen ECU) and normal 10.3:1 compression: 233whp and 230wtq.
So, the comp dropped 1.2:1, and he still got a gain, up 7whp peak, but it's a torque monster: up 25wtq thanks to better flowing upper end. Imagine the same % of gains on a boosted max!
Old Feb 11, 2005 | 07:27 AM
chris'smax's Avatar
So using the 3.5 heads brings down the compression right? Also would you want to use the 3.5 intake manifold or just keep the 2000 vi
Old Feb 11, 2005 | 07:55 AM
IceY2K1's Avatar
Out of 15-20 blown motors on the 350Z board I read, there are A LOT more, 1-2 are suspect of this issue.
I'd guesstimate this is a 10% or less occurance and people are using it as an escape goat to sell their "solution to the problem". Problem really is that Nissan weakened the internals by reducing weight and when people throw TT kits that produce healthy amounts of torque at low RPM, rods bend/snap. Even Nissan knows the rod bolts can't sustain 7200+rpm, so Nismo sells rod bolts, and even after those they don't specify any higher. Then for the 2005 "300hp" Z and "290hp" G, they redesigned the COMPLETE rotating assembly. So, apparently Nissan has something in mind for the future or the 3rd gen VQ35s were near their limit at 287hp to cause a complete redesign for a minor 13hp increase.
Anyways, the CPS->ECU shielded cable is not just a "simple" black/white here is the answer to your bending rods as you made it sound.
Old Feb 11, 2005 | 07:59 AM
Nealoc187's Avatar
SLOW
What I've heard is the crank signal issue as well. I've heard that the 350z ECU is screwy in that it does not respond well AT ALL to piggyback management. Supposedly it tries to thwart the efforts of piggyback ecus and revert to less FI friendly parameters. I know a guy (same guy Jason knows) who put almost 500 to the ground on stock internals, and there are others too. Most of these folks are running standalone to my knowledge, which takes the quirkiness of the 350z ecu out of the equation.
Old Feb 11, 2005 | 08:03 AM
IceY2K1's Avatar
BS....tons of guys running Greddy kits in 400+whp for over a year now and even more ATI Procharger guys.
It's a witch hunt.
Old Feb 11, 2005 | 08:12 AM
Nealoc187's Avatar
SLOW
It's a witch hunt.
What is? The crank signal issue or the ECU/piggyback issue?
Old Feb 11, 2005 | 08:13 AM
IceY2K1's Avatar
Yes, it would drop compression.
The intake ports on the newer VQ35 heads are angled different and require a VQ35 manifold. However, you could use the 2001-2004 Pathfinder VQ35 heads maybe, since they used a similar type port.
You're SC'd, so you don't need/want to drop compression, just buy cams and you're going to flow plenty of air.
Old Feb 11, 2005 | 08:14 AM
IceY2K1's Avatar
Both...........
Old Feb 11, 2005 | 08:18 AM
Nealoc187's Avatar
SLOW
Well that's what I was told by the guy with the ~500whp greddy kit so that's what I was going by.
