Disabling EGR
Old Mar 15, 2005 | 10:45 AM
Morfeus17's Avatar
Disabling EGR
Ok.. I know this question popped up a few times on this thread. But, I need to know how to disable the EGR? During boosting to about 6psi, the car starts to buck/hesitate a bit. From what was mentioned, bypassing the EGR may eliminate this problem.. Well I would like to put this to the test.
To illustrate things, at 5-6psi of boost,
1. EGT's are around 1375F-1420F.
2. Fuel Pressure shows 65psi. (This can be adjusted, but I may be reaching the max on stock injectors)
Fuel Reqs:
1. Walbro 255 Fuel Pump
2. Vortech SMFU
3. Stock 270cc Injectors
4. Stock MAF
5. Stock Programing
Old Mar 15, 2005 | 10:49 AM
chris'smax's Avatar
i also need to know this since i am putting my hotshot headers on this week which requires the EGR to be eliminated on my car
Old Mar 15, 2005 | 01:45 PM
SPiG's Avatar
SomePsychoGuy
If you have a 95 so you have 240cc side feed injectors.
Basically you put a plate blocking off the EGR port on your IM and put a big bolt in the place where it bolts into the rear exhaust manifold. Then you must put some resistors in the wires where it connects to the ECU..
Old Mar 15, 2005 | 06:09 PM
Morfeus17's Avatar
Yes.. I do have a 1995 maxima with side feed injectors. With repect to the EGR, blocking the EGR ports on the Intake manifold and exhaust manifold should not be an issue. But the resistors, is questionable.. What resistors do I use and how many? Is there a Write-up on this??
Old Mar 15, 2005 | 07:01 PM
Broaner's Avatar
2060lbs and falling...
No resistors are required. Just leave the one plug plugged in. It won't throw a code. For more info check the Definative EGR Thread
Old Mar 16, 2005 | 05:07 AM
chris'smax's Avatar
So broaner are you removing your EGR?
Old Mar 16, 2005 | 10:40 AM
Broaner's Avatar
I been done that two months ago y'all But I have not driven yet to see if the rumors are true.
shilov
Feb 19, 2024 09:40 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
maxima297
Sep 24, 2015 10:31 AM
bumpypickle
Sep 19, 2015 01:07 AM
A32goldylocks
Sep 2, 2015 06:39 AM
