Wiring Push Button Ignition
Ok, I need to know which wires to tap for a push button starter. I don't have a manual in front of me, and the car is sitting at the shop and I need to take it home today. We just can't figure out which two wires we have to tap into. Without the starter, the car won't always start obviously, so I need to get that wired in. Thanks.
http://www.importmodifications.com/i...onstarter.html
http://forums.maxima.org/showpost.ph...96&postcount=8
This should help since you need the key to start.
Hope you get it running.
Yeah, I figured it out after stripping just about every wire and testing it. Car's back at our shop right now and it should make it home ok. The pushbutton does work like a charm.
Still have the weird battery drain problem to sort but that should be figured out eventually.
Derrick2k2SE
Nov 19, 2015 10:14 PM
