fuel system upgrade
Old Mar 26, 2005 | 08:38 PM
sleeper's Avatar
fuel system upgrade
i removed all the stuff for installation of 370cc injectors, adjustable fuel pressure regulator, earls hoses and fittings, z32 maf, and while i'm at it i will redecorate, lol. and maybe install a wet system. this is gonna take some time.
Old Mar 27, 2005 | 08:09 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Glad to hear that off rail compression fitting is working for you.
Old Mar 27, 2005 | 09:12 AM
sleeper's Avatar
yes sir ree bob. that is a sweet tasty treat. lol. i havn't installed it yet though. the freaking stock fpr screws are on so tight, and the injector cap screws too. how did you get them things off without stripping the heads. i will definatly replace them with another type of head. i spayed the threads and they sat over nite. i will try later to se if they loosened up any. i can use needle nose vise grips if need be, or saw the phillips head to flat, what a pita.
Old Mar 27, 2005 | 10:03 AM
slimer's Avatar
i cut the stock fpr off.
those screws for the caps are a PITA, i had to cut one of them and made it a flat head to get it out.
BkGreen97
Apr 2, 2016 05:47 AM
