What temp should EGT be?
Old Mar 27, 2005 | 05:50 AM
dadiesel's Avatar
Need some help with EG temp. What degrees should I be running at during WOT?
Old Mar 27, 2005 | 06:02 AM
MardiGrasMax's Avatar
not much over 800c
Old Mar 27, 2005 | 07:04 AM
dadiesel's Avatar
Would around 800 be a good A/F mix?
Old Mar 27, 2005 | 11:05 AM
while EGT and AFR are related it is not wise to tune AFR using EGT. You can take it to a dyno with AFR and compare your EGT to the AFR, then you have a solid idea. But once you change somthing in the set up you have to go back to the dyno. If AFR is wht you are after get a wide band AFR set up.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
fastcarny
Oct 6, 2015 10:42 AM
msellas
Sep 23, 2015 09:16 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
