6-7psi with stock clutch??
Old Mar 29, 2005 | 04:25 AM
maxspeed96CT's Avatar
The original VQ...
Can i run 6-7 psi with a stock clutch???
Without to much beating, how long would this last me?
Old Mar 29, 2005 | 06:24 AM
I30tMikeD's Avatar
SC, maybe for a little while
Turbo, probably a day
Old Mar 29, 2005 | 06:25 AM
JAY25's Avatar
This is what I can tell you. I would not advise you to do that but if you dont have the money right away I am sure you can for about 90 days. Also if you drive senseless that clutch will die on you.
I seen a .org member here in Ga boosting 11.5 psi on a stock clutch. He did it for along time and I have videos of me racing this person. His car also had over 90K.
Old Mar 29, 2005 | 07:25 AM
The original VQ...
Ok how about 5psi, cause i am wondering if i can run it for about 2-3 months till i get the money for a clutch and flywheel.
Old Mar 29, 2005 | 07:27 AM
I30tMikeD's Avatar
Why don't you spend the money on the clutch first then boost later?
Old Mar 29, 2005 | 08:10 AM
Redmax's Avatar
Redlinemax Owner
mike your right buy the clutch first, however if you take the cause and effect route then he will boost the car which will make him buy the clutch. otherwise he may buy the clutch and never get the money together for the boost. I'm kind of glad I got the boost first because if I didn't and I was buying all of the other stuff first, then it would have been less stressfull but I would have found other things to do with the money
Old Mar 29, 2005 | 08:15 AM
Jeff92se's Avatar
I'm needing a caw
Depends on how you drive. Drive hard = ruin clutch in short order. Granny the car = clutch will last as long as you wish.
Common sense prevails here. I bet you could boost to 6-7 psi easy as long as you boost in gear and not shift hard.
Old Mar 29, 2005 | 11:14 AM
The original VQ...
cause my clutch is still good, and i dont want to do the work of changing it untill i need to...ya im lazy
but in all i think im just gona start collecting parts but hold off the project for a while.
on another note, are our booste cars daily drivers?
Old Mar 29, 2005 | 11:30 AM
Bags's Avatar
VG Ridah's Biatch Hoe
man, I need to really get some of these threads together
Old Mar 29, 2005 | 03:48 PM
I30tMikeD's Avatar
Mine is for now. I will proabably get another car just for winter. But besides winter it will still be my daily driver. But I also live 5 minutes from work
For my install I took 10 days off work and had another car available. I needed about that whole 10 days to get everything taken care of
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
