Help! Removing SuperCharger Pulley
Old Mar 31, 2005 | 08:42 AM
linuxr's Avatar
I have my SuperCharger off and cannot unscrew the setscrew that holds the pulley on. What did they do glue it in? Any know how to get it off so I can put my 3.33 pulley on?
Old Mar 31, 2005 | 09:14 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
http://forums.maxima.org/showthread.php?t=391809
its like 15 threads below this one.
make sure you are using the correct allen key.
Old Mar 31, 2005 | 09:51 AM
linuxr's Avatar
Thanks for the info. It is being a ***** to get out, Done twisted 2 wrenches on it.
Old Mar 31, 2005 | 09:58 AM
slimer's Avatar
they probably used loctite red, bastards
is it used?
Old Mar 31, 2005 | 10:28 AM
ptatohed's Avatar
Licensed to Spell
Slimer, I think linux is asking about the actual flat allen bolt holding in the pulley, not necessarily removing the pulley itself from the charger as The Wizard was asking.
Linux, what are you doing to stop the pulley from turning as you attempt to loosen it?
Mine was pretty stuborn too. The Wizard and I broke one allen wrench and we just barely got my bolt undone right before the second wrench was about to break (but not before making the wrench a pretzel!). We used a 2' pipe over an allen wrench. We stopped the pulley from rotating by being creative and using the belt folded over on itself and wrapped around the pulley a few times to keep it from rotating.
Good luck.
Old Mar 31, 2005 | 10:33 AM
slimer's Avatar
use an oil filter type strap wrench. and allen sockets
Old Apr 1, 2005 | 07:18 AM
linuxr's Avatar
Im replacing the Cheap plastic pulley from the stillen kit with a new ASP 3.33. We are using the old belt that was on the SC to hold the pulley and have a new Short Allen wrench socket. I'll have the car done today and should be testing out the new 3.33 today. Thanks, for the help.
Old Apr 1, 2005 | 07:23 AM
Stephen Max's Avatar
It is the idler pulley that is plastic, not the supercharger pulley. The SC pulley that comes with the kit is aluminum.
Old Apr 1, 2005 | 09:59 AM
linuxr's Avatar
Well, No luck yet, broke 2 allan wrenches and broke 2 snap-on sockets trying to get the damn thing off. Guess Im gonna have to drill the damn thing out and get a new one .
Old Apr 1, 2005 | 12:23 PM
Don't give up bro, you'll get it. Ptatohed and I got his off with some muscles/creative thinking. We also put a minor amount of "Liquid Wrench" on the bolt and let it sit for hours. We would come back every 30 minutes or so and add a few more squirts. Give it shot if you haven't done so already.
James
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
