Air/Fuel setup question
Old Apr 1, 2005 | 01:28 AM
Oblongshapes's Avatar
Does the FMU regulate the base FP, or does it only adjust fuel when boost is present?
Im trying to figure out my A/f setup... Im curious if a Z32 MAF, 370cc Injectors, 255 Walbro, and a Super FMU ( and maybe a safc2 or emange) would be a good setup to run. Or if I need an AFPR in addition to control base pressure at start and idles>?
Ive been reading post and trying to figure it out, but theres so many different theories and setups floating around..
Old Apr 1, 2005 | 01:36 AM
Brad92SE's Avatar
An FMU only increases fuel pressure when it sees boost. I don't know how well that setup will work for you, but my guess is that you will need an adjustable fuel pressure regulator, since installing a Walbro pump will raise your base FP.
Old Apr 1, 2005 | 10:16 AM
dadiesel's Avatar
The cartech FMU is adjustable right?
Old Apr 1, 2005 | 09:52 PM
LatinMax's Avatar
What FMU do you have? If you have a the regular Vortec or the Cartech. Then you will neet a ajustable fuel pressure regulator.
Old Apr 2, 2005 | 10:49 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
but....
if you have the vortech superfmu, you dont need and extra afpr because it is built into the unit itself.
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
