255lb waltoboro problems
Old Apr 10, 2005 | 08:03 PM
95turbo gxe's Avatar
Ok I took the stock fuel pump out and put in the 255 today.I was seeing knock levels of the 230 with the stock pump and thought this would solve the problem. I
have 259cc injectors with stock regulator. Well mtcookson had the same set up and his knock never got above 100 or so. So what could make my levels go so high.
Ok my fuel pressure is at idel at 36psi
Well I have the stock regulator and when I put the 255 in the pressure went to
43 at idel witch is more than likely pig rich. why did it change?
ok the fuel pump voltage goes down around 11.5 at wot.Mtcookson has this same pump and his stays around 12.3 to 12.5 i beleive. But at idel mine is around 11.8 but the the more throtle you give the more it goes down. .
WHat to do?
Old Apr 10, 2005 | 08:41 PM
Bags's Avatar
VG Ridah's Biatch Hoe
your car and his car are the exact same?
The 255 is a bigger pump, so it changed the pressure
WHat to do?
Run a new wire from the fuel pump relay to the duel pump and see if that solves the voltage drop and see if the knock levels drop.
Less voltage = Less flow
Old Apr 10, 2005 | 09:58 PM
subs1000w's Avatar
quite honestly i wouldnt trust an AFCs knock level indacator with my life.
why not get a wideband or go to a dyno and acually see what your A/F ratio looks like
why not get a FMU to sqeeze more fuel throught those 259cc injectors which i would guess are at 100% duty cycle under boost
im just curious but why do you have 370cc injectors listed in your sig when you have 259s installed
Old Apr 11, 2005 | 07:33 AM
DanNY's Avatar
Ad·min·is·tra·tor
"future upgrade" ?
Old Apr 11, 2005 | 11:09 AM
96_vqmax's Avatar
Originally Posted by Bags
[Originally Posted by 93turbo gxe
43 at idel witch is more than likely pig rich. why did it change?]
I got the walbro255 pump too,with stock fpr and stock injector,my car run little rough(like motor shake a little and go away after that) at around 1500 rpm,do your think the pump rising the base fuel cause it rich,but it idle fine?Any boby got this same problem?Do your think will the adjust fpr bring back the base fuel will stop this?
Old Apr 11, 2005 | 01:11 PM
subs1000w's Avatar
i have the 255lph and it also bumped my WOT fp to 52psi and i had to get an afpr to lower it back to 43psi but my car hasnt had a steady idle for as long as i can remeber so i dont know about that but it definitly ran rich
Old Apr 11, 2005 | 06:23 PM
ok the 370cc i have but do not have apr to use them and the 259cc were just laying their.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
