fuel system
Old Apr 10, 2005 | 08:41 PM
sleeper's Avatar
fuel system
i did some more stuff today. new fuel filter, fuel line into rail is complete. mounted fuel pressure regulator, and wired z32 plug in. i started removing old ecu. can anyone tell me a easy method.
http://image36.webshots.com/37/1/60/...1CijOAb_ph.jpg
http://image30.webshots.com/30/1/38/...0zOYwnX_ph.jpg
http://image48.webshots.com/49/0/23/...9kwLoLv_ph.jpg
Old Apr 10, 2005 | 08:45 PM
Bags's Avatar
VG Ridah's Biatch Hoe
the links don't work, can't post a direct pic and can't click on the link to see the pics
Old Apr 10, 2005 | 08:48 PM
Bags's Avatar
on the ecu, bend the metal supports , it's a PITA to get out
Old Apr 10, 2005 | 09:00 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
i cant see them either.
Old Apr 10, 2005 | 09:41 PM
I30tMikeD's Avatar
ECU removal? Don't try and remove the ECU from the bracket (little screws), remove the whole bracket and ECU together. Still a PITA. Never did get it to ever go back in right.
Old Apr 11, 2005 | 05:18 AM
stephenlc's Avatar
wow that yellow would kill me.
Old Apr 11, 2005 | 11:38 AM
96_vqmax's Avatar
That yellow shine so bright,is that powder coat or paint?
Old Apr 11, 2005 | 12:02 PM
Stephen Max's Avatar
By far the easiest way to remove the ecu is with this:
http://www.harborfreight.com/cpi/cta...emnumber=32940
Use the V-notched bit and put it against the head of the screw. The screw will shear off very neatly. Do all four screws (takes maybe 2 minutes) and you can slide the ecu out and the new one in.
Old Apr 11, 2005 | 07:27 PM
sleeper's Avatar
ecu removal
thanks guys for all of your ideas. i will try a couple things later this week and let you guys know what i did.
yellow powder coat.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
