Using e-Manage's VTEC function as an rpm switch?
Old Apr 17, 2005 | 03:54 PM
MAXimumHP's Avatar
I've been trying to get my e-Manage's VTEC function to work as an RPM switch to control my manifold. Has anyone successfully done this? I imagine it can be done, but can't seem to make it work. All I get is a .65 volt signal from it all the time.
Two questions I guess I have that might help me figure this out is, do I need a VTEC input to the e-manage. obviously I don't have one, but do I need to run a constant power to it or something to make it work. And what does the VTM do?
An opinions are appreciated.
Old Apr 17, 2005 | 05:03 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
did you get that vias on erik?
Old Apr 17, 2005 | 06:15 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I think you have to switch the jumper settings inside to activate the vtec properties, look on the Emanage forum or mailing list, there was a similar discussion a few weeks ago about using that function on non-vtec/non-Honda vehicles.
Old Apr 17, 2005 | 07:03 PM
MAXimumHP's Avatar
Just about ready to go on, but I wanted to get this working first.
I switched the jumpers around. Something is obviously wrong, because nothing is happening when I hit the correct RPM. (unless it's something other than a voltage change) Even if I get it to change, I don't know how I'll hook it up to a relay if it shows voltage before vtec is engaged.
I also tried using the sub-injector map and setting the value from 0 to 100%, but that doesn't switch voltage on and off either.
gavin68
Sep 18, 2021 12:36 PM
Need help
23
Oct 2, 2015 08:56 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
