Will this work for the Outlet side ??
Old Apr 18, 2005 | 08:53 AM
matty's Avatar
http://www.atpturbo.com/Merchant2/me..._Code=SIL-90EL
Its 2.5" to 3" transition...I know that the oulet on the blower is 2.75, but yout think Ill be able to get it around the outlet good enough ??
-matt
Old Apr 18, 2005 | 09:19 AM
Stephen Max's Avatar
-matt
Maybe, but I bet it won't be easy.
Old Apr 18, 2005 | 09:23 AM
matty's Avatar
Well stephen if I get 3" to 3" elbow how can I "Beef" up the Outlet side to meet the 3" silicone coupling. ?? its only really another .25 of an inch
Another option I was thinking was going with that intake piping you were saying you used from a 300ZX, (ebay item ?? i lost the link maybe you have the link still ?) and getting away from the 90 degree bend
-matt
Old Apr 18, 2005 | 09:43 AM
DanNY's Avatar
Ad·min·is·tra·tor
can you explain what you're trying to do? the outlet on the blower is 2.75 and you want to know if this 3" will work?
Old Apr 18, 2005 | 09:48 AM
matty's Avatar
Im trying to order material for my 3" charge pipe. The First link i posted up was 2.5" witch would go onto the 2.75" Oulet...
Then I wanna know what I need to do to the 2.75" outlet to make it OK for the 3" coupling
-matt
Old Apr 18, 2005 | 09:51 AM
DanNY's Avatar
Ad·min·is·tra·tor
-matt
a 2.5 coupler to a 2.75 outlet..that would be a realllll tight fit..no?
well i answered your question in the WTB thread. basically you want to use a sleeve in the 3" coupler to get it down to 2.75". try to use silicone...they tend to stay a little "sticky" so they don't pop off.
Old Apr 18, 2005 | 09:52 AM
matty's Avatar
Thank you alot
Old Apr 18, 2005 | 10:59 AM
-matt
You can use boost hose to build up the diameter to 3". You should be able to find 2.75" dia boost hose pretty easily. Most boost hose is nominally 1/8" thick, so there you are at 3".
Old Apr 18, 2005 | 11:56 AM
matty's Avatar
Do you have a link to that 300ZX Intake part that you have used ??
Old Apr 18, 2005 | 12:46 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
so you really think that it will hold it on with 14 psi of boost getting backed up and released?
Old Apr 18, 2005 | 01:03 PM
I have blown hoses off a couple of times since installing the 2.87" pulley, but never that particular one. It's always the ones on the polished aluminum pipes up front. Not enough friction.
Old Apr 18, 2005 | 01:36 PM
No link, but I have a picture of it somewhere, if that is what you want.
Old Apr 18, 2005 | 01:40 PM
matty's Avatar
ahh im just gonna go with the 90 degree coupling
thanks
Old Apr 21, 2005 | 10:32 AM
maxima_kid's Avatar
-matt
I think you should find out how HiTemp can the HiTemp rubber can withstand.
Old Apr 21, 2005 | 11:14 AM
Blu's Avatar
Blu
the tits
have you tried spraying hair spray on the pipes that join into the couplers?
Old Apr 21, 2005 | 11:21 AM
That sounds like a good tip. I'll try that.
Old Apr 21, 2005 | 11:31 AM
Blu's Avatar
Blu
the tits
works like a charm
Old Apr 25, 2005 | 02:56 PM
matty's Avatar
Sooo all the Couplers have to be 3" and the T-Bolt Clamps all have to be 3.25" (exept the TB which is 3" T-bolt) ??? Before I place this $200 order
-matt
Old Apr 25, 2005 | 08:23 PM
slimer's Avatar
yup-order it!
jerrod99_se-l
Aug 27, 2015 08:27 PM
Max8
Aug 20, 2015 07:20 PM
shaunkey1
Aug 18, 2015 10:09 PM
jchronis2552
Aug 13, 2015 07:48 AM
kenc15
Aug 5, 2015 08:29 AM
