Clocking Blower
Old Apr 18, 2005 | 12:34 PM
matty's Avatar
Clocking Blower
Im about to order $180 worth of T-Bolt Connectors and Silicone Couplers...
Would it be more worth it to Clock the blower up to do away with the 90 degree Bend at the the blower oulet ?
Im doing a 3" cross over pipe...Starting with::
90 degree coupling + 45 degree Coupling + 22" of 3" pipe + 45 degree coupling + Straight Coupling to the MAF adaptor
-matt
Old Apr 18, 2005 | 01:00 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
its hard to go without some sort of 90 degree bend.
i have a 45 degree coupling that i dont think that i will be using.
talk with me about it more over aim or pm.
Old Apr 18, 2005 | 01:40 PM
Stephen Max's Avatar
No matter how you clock the blower, you are going to have a total of at least two 90's and a ~45 on the way to the throttle body.
If you want to get rid of the hard left turn right at the blower outlet, then you have to clock the blower down and cut into sheet metal. Kinda scary the first time.
Old Apr 18, 2005 | 01:44 PM
matty's Avatar
this wont work ??
Old Apr 18, 2005 | 02:50 PM
Chunger's Avatar
My other car is a Hybrid
You do know that the outlet from the blower is 'only' 2.75" right? (it's a size difficult to find tubing for admittedly)
There really won't be any significant "improvement" to flow by clocking it up... just easier to access piping and giving more room behind headlight.
Old Apr 18, 2005 | 02:56 PM
matty's Avatar
[QUOTE=Chunger]You do know that the outlet from the blower is 'only' 2.75" right? (it's a size difficult to find tubing for admittedly) QUOTE]\
yea ill figure out what im gonna do when the time comes
Old Apr 18, 2005 | 03:46 PM
slimer's Avatar
it will get rid of that little cutout that stillen makes us have.
i agree about the room too. made much more room for my cefiro headlights.
Old Apr 19, 2005 | 05:48 AM
cardana24's Avatar
Blown
I have two, 2.5">>3" couplings in black if you need them let me know
Old Apr 19, 2005 | 08:27 AM
vortechpower's Avatar
I think going around the front is the best way to go! I think it looks more complicated then it is. Although I have not done this so I wouldnt know. I found a guy that will make you an intercooler/piping and install it for $500! spark any interests? I need to get more info on this..
Old Apr 19, 2005 | 08:44 AM
chris'smax's Avatar
if it is in stainless steel for 500, yea i would be interested
Old Apr 19, 2005 | 12:33 PM
Blu's Avatar
Blu
the tits
Yes it does, and yes you do........With the T-trim pushing a lot more air I will not loose as much boost running a FMIC. Let me know...
shilov
Feb 19, 2024 09:40 PM
t6378tp
Sep 29, 2018 04:27 PM
knight_yyz
Nov 1, 2015 01:34 PM
viperboy
Sep 27, 2015 07:05 PM
